Eagle Cap 1165/1200 headroom
11 replies to this topic
#1 OFFLINE   alexb123
alexb123
  • Local time: 09:11 PM
  • State/Province or Region:Kentucky
Posted 27 August 2018 - 01:14 AM
How is the head room in the eagle cap 1165 or 1200?  It is listed as 76 inches, but why is it lower than the smaller eagle caps?  I am 6'5", is it too low?
#2 ONLINE   Bedlam
  • Local time: 12:11 PM
Posted 27 August 2018 - 07:38 AM
Those models have the floor start above the bed rails of the truck rather than above the wheel wells of the other models. Although it does allow for more floor space it makes the overall camper taller too. I'm over 6' and fit in these models without my head touching, but I'm not sure at your height if you would clear the air conditioning shroud inside.
#3 OFFLINE   alexb123
alexb123
Posted 27 August 2018 - 04:16 PM
how high is the ceiling in the center?
  • 1956 posts
  • Local time: 02:11 PM
Posted 31 August 2018 - 07:27 AM
The Eagle Caps the Adenture big boys all have the floor above the bed like Bedlam mention and the ceiling flat all the way to the nose the shroud for the AC drop down 3-4 inches so the height the same except at the AC
#5 OFFLINE   alexb123
alexb123
Posted 01 September 2018 - 01:50 PM
The height is listed at 76 inches, so it's taller than that in the center, and it only drops down at the nose shroud, or is it that tall before the AC, and then it drops down further?
Edited by alexb123, 01 September 2018 - 02:20 PM.
  • 1956 posts
Posted 08 September 2018 - 03:21 AM
It's flat till the nose cap. Main thing that drops down is the A/C shroud ours is around 3 inches
#7 OFFLINE   alexb123
alexb123
Posted 08 September 2018 - 10:58 PM
So is it above 76 inches (the listed height) until the nose cap, and then it drops down to that, or is is 76 inches where it's flat, and then it drops down further at the nose cap?
#8 OFFLINE   KnightEagle
  • 1956 posts
Posted 09 September 2018 - 03:15 AM
In the adventure same till it gets to the nese cap except at the AC as you can see in the picture below at the door there is a step down inside by the door only
#9 OFFLINE   alexb123
alexb123
Posted 24 September 2018 - 02:19 PM
Yeah, but what is the height when it is the same?  Is it 76 inches, or is 76 inches the lowest it gets, when it goes down?
#10 OFFLINE   KnightEagle
  • 1956 posts
Posted 02 October 2018 - 04:44 PM
front to rear 76 at A/C 73 in side shower 67 more or less at the step down at the door app 84 more or less didn't go taking mesurements just trying to paint a picture.
#11 OFFLINE   Popparex
Popparex
  • State/Province or Region:Massachusetts
  • Camper Brand:none yet
  • Truck Make & Model:none yet
  • Name (Public):Rob
Posted 21 October 2018 - 09:49 AM
Being 6'5" (and a quarter... ;-) myself i looked at headroom pretty carefully. Ended up with the artic fox 1140 because of the curved roof giving me extra room. The eagle was an extra $5K and was too long a drive to bother with so i can't talk about the eagle specifically, but i think i'll be happy with the AF. (Still waiting for a truck to be delivered so have not had the opportunity to put them together and test it out)... point is you may want to look at the artic fox.
good luck!
#12 OFFLINE   KnightEagle
  • 1956 posts
Posted 13 November 2018 - 06:25 PM
Yea the AF-1140 is a nice TC We had the AF-990 before this Adventure we had it for almost 6yrs loved it then it seemed to die a slow death Gen gave out, micowave burn up hot water heater glass or liner started stopping up the faucets and shower head then the fridge crapped out. Not AF fault we just used the crap out of it.
