La Grande 2018 Rally Report
15 replies to this topic
#1 OFFLINE   RichConley
  • 2157 posts
  • Local time: 04:35 AM
Posted 16 July 2018 - 01:58 PM
Maybe someone else has photos from the rally.  If so, please feel free to post them here.
I'll start with a photo of the truck campers already built and waiting to be delivered to dealers.
Do you see your's there?
Attached File  complete-af-campers-0640.jpg   114.57KB   1 downloads
(click to enlarge)
#2 OFFLINE   Mr Firewood
Posted 16 July 2018 - 05:57 PM
Nope our new Host Mammoth Arctic Fox 1150 has not been built yet.  After touring Elliot's and Pete's newer rigs I love features in both.  So I want a hybrid combination
of both campers.  Sally on the other hand tossed a 3rd brand into the mix.  The Rugged Mountain Granite RL.  It's sort of a grandma camper.  No slides, all white interior.  I'd have to see one in person to form an opinion.  Thus far it's not in the running.
George
Posted 16 July 2018 - 06:25 PM
I was too busy talking with new and old friends to take pictures. Leaving the phone in the camper also reduced my urge to keep in touch real-time with work. They had to wait till EOD for responses.
#4 OFFLINE   Stan
Posted 17 July 2018 - 08:49 PM
WOW, what inventory. Why don’t they get those delivered?
#5 OFFLINE   Bedlam
Posted 18 July 2018 - 04:32 AM
Five roll out the door daily at this factory and they get delivered one or two at a time to dealers. Arctic Fox will do run of a particular model and then switch over to another. Right now, they are doing a three week run on 990’s.
#6 OFFLINE   RichConley
  • 2157 posts
Posted 18 July 2018 - 10:08 AM
A few more pics for the record.  Somehow I missed all the food and social photos - probably too busy stuffing my face.
First pic showing the Round top roof frame on the 2017 and newer Arctic Fox campers.
I think only the end sections of the camper are aluminum framed - the roof trusses are wood framed as far as can be seen in the photos.
(click photo for larger view)
Attached File  arctic-fox-roof--0592.jpg   138.45KB   1 downloads
Trusses;
Attached File  arctic-fox-roof--0630.jpg   147.49KB   1 downloads
Almost aircraft aluminum grade metal is used for the frame (The tour guide explained that the aluminum grade is one step lower than aircraft grade) They use this aluminum because it can hold a weld bead.
Attached File  weld-bead-0587.jpg   363.31KB   1 downloads
Wood is used inside the aluminum frame to provide solid backing for screws to bite into:
Attached File  wood-aluminum-0589.jpg   354.98KB   0 downloads
A few black tanks waiting to be installed in the days production of truck campers:
Attached File  black-tanks-0615.jpg   426.47KB   1 downloads
An overview of an interior of one factory building:
Attached File  factory-shot-0593.jpg   408.74KB   1 downloads
Shot of the sub-floor with water tanks being assembled:
Attached File  water-tanks-0618.jpg   413.81KB   1 downloads
Further along in assembly;
Attached File  water-tanks2-0619.jpg   395.76KB   1 downloads
We see the back end of a subfloor assembly:
Attached File  subfloor-0614.jpg   396.71KB   1 downloads
Slide opening motor.  On the far right is the slide support bar which rides in track which provides good support for the slide when its retracted.
Attached File  slide-mech1-0625.jpg   309.07KB   1 downloads
In the far background, with the blue fabric and clamps along the edges is a large vacuum bonding machine where the interior roof is laminated:
Attached File  vacumn-bond-0633.jpg   415.81KB   2 downloads
Meanwhile, back at the camp, Lady Law catches up on some quiet "me" time.
Attached File  quiet-time-0646.jpg   714.17KB   1 downloads
And energetic Cody plays with kite provided by Mr. Law;
Attached File  fun-kite-0659.jpg   721.15KB   1 downloads
Bedlam entertains some kids with wild action rides;
Attached File  bedlam-entertains-0648.jpg   568.03KB   1 downloads
I simply don't know about this.  Cooked fish on the line?
Attached File  fishing-0663.jpg   592.56KB   1 downloads
The camping group visited the Oregon Trail Interpretive Center in Baker City.  Very informative.  That's me standing like a tourist with my better half;
Attached File  interpretive-center2-0657.jpg   435.08KB   1 downloads
That's it - the real deal - evidence of some of the 500,000 people that rode and walked to Oregon - the "trail":
Attached File  oregon-trail-0653.jpg   778.33KB   1 downloads
Lastly but not least, one of the interpretive centers many displays;
Attached File  interprative-ox-0652.jpg   410.08KB   1 downloads
#7 OFFLINE   mtnkwby
  • 441 posts
  • Local time: 03:35 AM
  • State/Province or Region:CA/OR
  • Camper Brand:S&S 11SC
  • Truck Make & Model:1990 F350 S/C Lariat Dually, Camper Special
Posted 18 July 2018 - 08:49 PM
Sorry we couldn't make it, we leave in the morning for Enterprise, will be camping at Goose Lake Thursday and Friday.
1990 F350 S/C Dually Camper Special
1990 S&S 11SC Camper
2011 Ranger S/C XLT
#8 OFFLINE   stuwu4s
  • 762 posts
  • Local time: 07:35 AM
Posted 19 July 2018 - 12:11 PM
sorry we also did not make it to the La Grande rally either, but it was 2500 miles, one way. maybe the next one will be a little closer.
#9 OFFLINE   Stan
Posted 22 July 2018 - 05:25 AM
Planned on going until my old army injury got real bad. Thinking about knee replacement so I can start doing things again. Looks like the attendees had a great time. Hopefully next time. Rich puts on great rally’s, lots of work, he puts into them.
#10 OFFLINE   the tc life
  • 3747 posts
Posted 23 July 2018 - 04:44 AM
I am now back from my vacation Although it will take a bit for me t type up a rally report and then my trip report.
Thank you to all who could attend the rally. We had a great time.  Sorry about the really great weather. lol.
#11 OFFLINE   PigPen
  • 12484 posts
Posted 09 August 2018 - 11:10 AM
I know longer have an arctic fox product after my recent accidednt. It was a bit of a lemon anyway. I had a list of over 20 fairly serious issues with it, that were never addressed. I will not be buying an AF product again.
#12 OFFLINE   Electrojake
  • 132 posts
Posted 09 August 2018 - 09:30 PM
The next N-E Truck Camper Jamboree in Gettysburg, PA is a lot closer. September 12-16.
Just saying... It might be worth the trip up.  :cartwheel:
See this link -->> https://www.truckcam...urg-campground/
#13 OFFLINE   RichConley
  • 2157 posts
Posted 10 August 2018 - 06:29 PM
I feel the same way about my Lance.  Never again.
Funny though - the Arctic Fox factory tour part for truck campers looked very good.  Can't imaging condemning all their products based on one experience though.
#14 OFFLINE   Electrojake
  • 132 posts
Posted 10 August 2018 - 08:11 PM
What was the production year on that AF?
Just wondering.
Thanks!
#15 OFFLINE   PigPen
  • 12484 posts
Posted 29 August 2018 - 07:52 AM
2014. It had a litany of issues, some where caused by the dealer who is now defunct. They installed a slide awning wrong, a grab handle extremely crooked and did not Pre inspection, I had to stop by LaGrande and have things fixed. The dealer was back in California so too far to go. The first summer I found the solar panel they sold me had not been hooked up on the roof.   No wonder they went bankrupt.
The worst was a leak in the slide storage compartments which was never noticed since it was under the carpeting and was not visible until it got worse. I never did find the source even with pressure testing. The shower leaked behind a wall since day one and was in crooked as well, the structure holding the bed up cracked and I had to repair & reinforce that. They improperly installed a slide motor (schwinteck) it eventuallyl shifted out of place and one side of the slide would not come in. I had to jury rig it in an RV park. The stairs beoke (replaced with Torklift glow steps). The fiberglass noe cap oxidized badly. The Grey tank leaked where the outlet pipe entered, probably from day one, I never noticed until all the bat insulation was so soaked and heavy, it collapsed the floor underneath it. I supect a slow drip since day one and it explained the odd smell the trailer always had. Showed up just after warrenty expired, I fixed it myself. I had to repair the drainage plumbing inside in 4 locations as they pipes where so sloppy, under the kitchen sink, the bath sink and the outdoor kitchen sink. My plumbing skils are good, so I also fixed those myself. Found the microwave did not work after picking it up. Opened up power panel and found the wire was not even connected, just sitting there, unstripped. After 2 months the slide rollers were eating into the bottom of the slide, aluminum plates for them to roll on had to be installed. The outside kitchen door hingers snapped (cheap aluminum). It went on & on. I had 21 deficiencies in all, some were fixed under warrenty, some did not show up until after. I wrote a letter but heard nothing back.
I will never buy an AF product again. They used to have good quality control before Ron Nash had a stroke, I wonder if that is what has caused it to decline. In the old days I could have had Bob Mehrer talk to Ron and getr everything fixed, but those days are past with his death and Rons stroke.
The TV & DVD player were on opposite sides, both HDMI compatible but they ran an AV cable between them, the interference was terrible. Took a whole day for my brother & I to fish an HDMI cable between the 2 of them (bad design)
I had everything fixed except the slide compartment leak. i had every possible spot of leaking covered in painters tape and was in the proocess of removing it piece by piece and using a pressure washer to ID where it was coming in, when it got wrote off.
#16 OFFLINE   RichConley
  • 2157 posts
Posted 30 August 2018 - 05:35 AM
Sounds like my Lance. . .maybe they hired the Arctic Fox guy after he left?
I finally got the Schwintek slide out issue fixed by a GREAT shop in Lakewood, Washington: Southend RV Repair
