2018 F-150 Payload
#1 OFFLINE   treecutter
treecutter
  • 54 posts
  • Local time: 10:29 AM
  • State/Province or Region:ontario
  • Country:canada
  • Camper Brand:Arctic Fox 1140
  • Truck Make & Model:Ford F-450
Posted 12 July 2018 - 07:39 PM
I was checking the specs of the new F-150. 5 L V8 motor, 4X4, regular cab, 8' box, = 3040 lbs. of payload! There are several hard-side campers that can be carried on that truck. That is what I'd get if I was just starting out.
I've got 2 trucks and 2 campers: Daily driver is a 2001 diesel Ram with a Travel Hawk bought  new 18 years ago. Winter driver for going south to escape the snow is a 2016 F-450 and an Arctic Fox 1140.
  • 1443 posts
  • Local time: 07:29 AM
Posted 14 July 2018 - 11:15 AM
Look at the rear axle weight capacity and subtract the actual rear truck weight. That will be your limit for carrying a camper that is filled with water, propane and personal items.
#3 OFFLINE   Electrojake
  • 132 posts
Posted 15 July 2018 - 06:21 AM
I’ve learned my lesson well on this issue...
When it comes to loading up a truck camper and all the toys that go with it The first 4000 pounds of payload gets used up real, real quick.
After that things tend to level off.
The new F150 trucks (when properly configured) do indeed have some very impressive payload. :)
#4 OFFLINE   PACK4TAG
PACK4TAG
  • Local time: 09:29 AM
  • State/Province or Region:IA -AZ
  • Camper Brand:2001 825 LL EC Lance
  • Truck Make & Model:15 FORD 250 BRONZE GAS W/TAG
  • Name (Public):Roy
Posted 15 July 2018 - 12:43 PM
Remember "Payload" is higher than "slide in camper cert weight"
because of WHERE the weight is in relation to the tires.
#5 OFFLINE   Electrojake
  • 132 posts
Posted 17 July 2018 - 11:13 PM
Very nice equipment, BTW.
