Host Mammoth - What is in this space?
#1 OFFLINE   deonb
deonb
  • Local time: 12:33 PM
  • Camper Brand:Host
  • Truck Make & Model:Ford F350
  • Name (Public):deonb
Posted 02 June 2018 - 01:27 PM
Hi everyone!
Just put down a deposit on a Mammoth, and I want to do a few factory modifications - mostly cabling related.
I'm wondering what is behind the area in the picture below? There are no doors or access panels that I could see, so I couldn't take a peak.
Is there for example enough space to put in a compact Mac or PC, Wifi and LTE receivers and boosters and maybe an iDirect satellite router? Can I also run a bunch of coax and HDMI cables into this area?
Does it have 110v power in there?
From the outside it certainly looks like big enough, but wondering if something in there is taking up space already (e.g. shower drain).
Edited by deonb, 02 June 2018 - 01:29 PM.
#2 OFFLINE   Electrojake
  • 72 posts
  • Local time: 07:33 AM
  • Name (Public):-Ej-
Posted 02 June 2018 - 03:28 PM
You have great taste in campers. :)
My camper is not a Host but there are a few HOST owners here that will undoubtedly chime in shortly.
Welcome to the forum.
  • Local time: 04:33 AM
Posted 02 June 2018 - 09:41 PM
If you pulled the radio, you would have access to your shower plumbing. If you pulled the fireplace, you have access to cable runs coming from the basement.
There is 12vdc and 120vac power in this cavity. Without adding ventilation, I would not tuck additional electronics inside. The panels under and on either side of the radio could be opened up create storage or equipment cubes the depth of the shelf mantle.
