HAPPIJAC Wireless Remote Problem
12 replies to this topic
#1 OFFLINE   JerBear
JerBear
  • Founder
  • 993 posts
  • Local time: 07:59 AM
  • Interests:Camping,fishing and generally having a good time!
  • Camper Brand:2007 CITATION Supreme 10'8
  • Truck Make & Model:2006 GMC 3500 DRW
  • Name (Public):Jerry Gale
Posted 26 April 2018 - 11:40 AM
I am having an issue with my HappiJac wireless remote. The green light will not go off and if the main board is on all 4 jacks start to raise the camper. The only way to stop this is to pull the batteries or unplug the power from the main board. If the batteries are out of the remote overnight and I put them back in the next morning, the remote will turn on and off ok and the jacks work ok for maybe an hour. then after an hour or so if I go to turn on the remote, same problem. The green light will not go off and all 4 jacks lift the camper until I pull the batteries from the remote or pull the power from the main board. Any ideas??
JerBear
http://truckcampers.fanworks.org/kit_camper/images/4993956263_e150e3a2bc_z.jpg" />
2007 CITATION SUPREME 10'8" Truck Camper,TORKLIFT Fast Guns,COOPER LTX M/S LT215/75R16-E,TORKLIFT SUPER HITCH, TORKLIFT Tie Downs, REESE Front Hitch,,HONDA EU2000i Generator, RANCHO RS9000X Shocks, SUPER SPRINGS,2x100 Watt Solar Panel w/MPPT Controller,2500 Watt Inverter.
2006 GMC 3500 DRW Extended Cab Truck,Duramax/Allison
Kingston, Nova Scotia, Canada
FIGHT THE GOOD FIGHT......SUPPORT OUR TROOPS!
  • 1403 posts
  • Local time: 03:59 AM
Posted 26 April 2018 - 02:08 PM
If your remote allows tethered operation with a cord see if acts the same way - You could use the cord all the time as work around. If you cannot tether or the remote fails the same way on the cord, you need to buy a new remote control.
2015 Ram 5500 HD 4wd Tradesman 60" CA, Crew cab with 173.4" wheelbase, 19,000 lb GVWR with 26,000 lb GCWR, Cummins I6 6.7 liter diesel with chassis cab tune 325 hp @ 2800 rpm and 750 ft-lb @ 1700 rpm, Aisin AS69RC 6-speed automatic, New Process NV271 manual transfer case, 14.5k lb Dana S14-111L limited slip and 7250 lb Magna Steyr 275mm with 4.44 ratios, Palfinger Badger low sill flat bed, Dual DeeZee 36x18x18 under bed boxes, Quad DeeZee 48x18x18 above bed boxes, Curt Double Lock 30K lb gooseneck, Dual 3/4" horse stall mats, SuperHitch Magnum 30K dual receiver with 42" SuperTruss, Upper StableLoads, Short range FastGun turnbuckles, 10 Deka 24HR3000 sealed batteries
#3 OFFLINE   JerBear
JerBear
  • Founder
  • 993 posts
Posted 26 April 2018 - 02:59 PM
I tried plugging in my corded remote but think it has to be paired with the main board from the cordless remote. I know the corded remote is good because I used it all winter with the paired board. At any rate the corded remote did not work with the board from the  cordless remote.
#4 OFFLINE   Electrojake
  • 66 posts
  • Local time: 06:59 AM
  • Name (Public):-Ej-
Posted 26 April 2018 - 09:46 PM
Greetings JerBear,
Put new batteries in your hand-held-remote and then Try following the re-programming instruction in this link...
https://pantherrvpro...-your-receiver/
Regards,
#5 OFFLINE   JerBear
JerBear
  • Founder
  • 993 posts
Posted 27 April 2018 - 05:06 AM
Greetings JerBear,
Regards,
Not sure if re-programming it will work. I took out the batteries yesterday and when I put them in this morning it worked fine. An hour later and green light stays on and the same problem. Frustrating!!! Almost seems like after the batteries are in the remote for an hour or so the remote will not work.
#6 OFFLINE   Electrojake
  • 66 posts
Posted 27 April 2018 - 08:31 AM
FWIW...
My wireless HappiJac 4160's are only 6 months old and I have had a number of controller problems and a failed drive motor thus far.
Over the winter my jacks were getting weird and unreliable, then eventually they would not respond at all. I did the re-programming routine and now they work fine again, but I do NOT trust them. I took a fellows advice and installed an emergency power cut-off switch that I can access from outside the camper.
The re-programming routine is absolutely free and resets everything so (since nothing else works) I'd give it a try.  :fing32:
Please keep us posted on your progress because if it happened to 'you' it will most likely happen to one of 'us' too.
Good luck & best regards,
#7 OFFLINE   JerBear
JerBear
  • Founder
  • 993 posts
Posted 28 April 2018 - 02:30 AM
OK EJ...like you said nothing else is working. Will give it a try and report back
JerBear  :canada:
#8 OFFLINE   Chief 2
  • 55 posts
  • Local time: 05:59 AM
Posted 28 April 2018 - 03:05 AM
Hey Jer,
     Load that TC up and get back down here to Tenn. We miss you guys.
#9 OFFLINE   JerBear
JerBear
  • Founder
  • 993 posts
Posted 28 April 2018 - 11:46 AM
Hey Jer,
Hey....we miss you guys too!!!! How is the shopping going?
#10 OFFLINE   JerBear
JerBear
  • Founder
  • 993 posts
Posted 30 April 2018 - 09:30 AM
#11 OFFLINE   JerBear
JerBear
  • Founder
  • 993 posts
Posted 30 April 2018 - 09:32 AM
Hey Ej
Tried reprograming my remote on the weekend but made no difference. Still having the same problem. Thanks for your suggestion!!
JerBear
#12 OFFLINE   Electrojake
  • 66 posts
Posted 30 April 2018 - 02:49 PM
Hey Ej
JerBear
Sorry it didnt help.
BTW.... The old thread listed below may help some.
And do keep us posted on the final outcome.
Regards,
#13 OFFLINE   JerBear
JerBear
  • Founder
  • 993 posts
Posted 03 May 2018 - 10:36 AM
Looks like I will have to use my old wired remote or buy a new wireless remote. Glad I have my old wired remote for backup.
JerBear
