Boat trailer towing
#1 OFFLINE   sunliteowner
sunliteowner
  • 22 posts
  • Local time: 11:59 AM
  • State/Province or Region:indiana
  • Country:us
  • Camper Brand:sunlite
Posted 25 April 2018 - 10:30 AM
Has any one used a cargo carrier on back to tow a boat?  I'm thinking aluminium to keep weight off bumper. Would steel be stronger?
  • 1403 posts
  • Local time: 03:59 AM
Posted 25 April 2018 - 12:49 PM
You can carry a boat on a basket as long as the boat dimensions will not cause width or height issues. It will most likely block the rear door of your camper, so you will not have access until you unload the boat.
If you talking about hitching your boat trailer to a cargo basket, I have not seen any that were strong enough. If you plan to tow behind your camper and need an extension, you should be looking at the SuperHitch and SuperTruss from Torklift.
2015 Ram 5500 HD 4wd Tradesman 60" CA, Crew cab with 173.4" wheelbase, 19,000 lb GVWR with 26,000 lb GCWR, Cummins I6 6.7 liter diesel with chassis cab tune 325 hp @ 2800 rpm and 750 ft-lb @ 1700 rpm, Aisin AS69RC 6-speed automatic, New Process NV271 manual transfer case, 14.5k lb Dana S14-111L limited slip and 7250 lb Magna Steyr 275mm with 4.44 ratios, Palfinger Badger low sill flat bed, Dual DeeZee 36x18x18 under bed boxes, Quad DeeZee 48x18x18 above bed boxes, Curt Double Lock 30K lb gooseneck, Dual 3/4" horse stall mats, SuperHitch Magnum 30K dual receiver with 42" SuperTruss, Upper StableLoads, Short range FastGun turnbuckles, 10 Deka 24HR3000 sealed batteries
#3 OFFLINE   sunliteowner
sunliteowner
  • 22 posts
  • Country:us
Posted 26 April 2018 - 06:57 AM
Thanks I found a Reese hitch that is made to carry a cargo platform on top and it inserts into a class 3 receiver to tow a trailer. 4000 lb cap. My tong weight is maybe only 80 lbs. 15 foot boat trailer.
