Host Mammoth- looking for real life info on weights and height
#1 OFFLINE   Soos
Soos
  • Local time: 07:51 AM
  • State/Province or Region:TX
  • Country:United states
Posted 09 March 2018 - 04:05 PM
Hey there,
We have narrowed our TC search to a Host Mammoth and one other.
Our current truck is a 2011 F450, we will be ordering a late build 2019 F450 (waiting for 10 speed transmission).
I am trying to get some real use numbers on height and weight.
I understand everyones set up is different but want to get an idea. We are set on the 450 because we also have a 5th wheel.
Thanks for any info!
Sue
  • 1438 posts
  • Local time: 12:51 AM
Posted 09 March 2018 - 09:20 PM
The Mammoth will weigh around 4500 lbs dry and is 9.5’ tall. Expect the camper to be closer 6000 lbs by the time you fill and load it because it has considerable storage and large tanks. Your overall height when loaded will be over 12.5’.
#3 OFFLINE   Soos
Soos
Posted 10 March 2018 - 09:44 AM
Thanks for the feedback!
Glad to hear the height....Was hoping it wouldnt be too far over 13’
