Host Mammoth Owners 2016 to 2018
mammoth
1 reply to this topic
#1 OFFLINE   mammoth
mammoth
  • Local time: 01:29 AM
  • State/Province or Region:Co
  • Interests:Camping winter, summer anytime, boating, sleds,ATV's, learning more about the new Host camper line(s) mammoth.
  • Camper Brand:HOST
  • Truck Make & Model:Volvo 670 Semi
Posted 26 February 2018 - 07:48 PM
I am new to this site and recently purchased a 2017 Host Mammoth after researching them for a number of years.  Had a Arctic Fox 1150 and other brands prior.  So we love the 3 slides, now I would like to know what to watch out for on this brand.  I am tearing things apart as time permits.  Let me know your thoughts.
  • 1438 posts
  • Local time: 12:29 AM
Posted 27 February 2018 - 05:46 AM
Other than making sure all doors and drawers are secured and the floor is clear before bringing in the slides, it’s not much different than your Arctic Fox. Since these slides are flush with the floor, even carpet or mats will interfere if they are not stowed.
Do you have the Host on the Volvo? I’m sure everyone wants to see pictures.
