Seattle RV Show Feb 8-11, 2018
#1 OFFLINE   Bedlam
  • 1365 posts
  • Local time: 10:19 AM
Posted 05 January 2018 - 01:36 PM
Seattle's RV show is February 8-11.
http://seattlervshow.com/
https://www.facebook...heSeattleRVShow
Use the link bellow if you plan to attend to get a discount:
https://www.mhrvshow...cfm?id=WSECUMem
2012 Interstate Car Carrier ICC10220TA3, 20'x8.5', 8" I-beam frame, dual 5200 lb 4" drop torsion axles, Diamond plate, Towmax 225/75R15 LRE tires on galvanized rims, Harbor Freight 10k lb equalizing hitch, Camping World vent cover, LED lighting, 3' RV door, front and rear door interior light switches, interior plywood walls and floor, 70' of Harbor Freight E-track rail with recessed corner 5k lb D-rings, Dual 42 gal fresh water tanks with Harbor Freight transfer pump, portable dual  Harbor Freight 45w solar arrays, 100 lbs LPG in four bottles, PowerArmor Max Solar 5-battery box, Deka 24HR3000 sealed batteries
2015 Ram 5500 HD 4wd Tradesman 60" CA, Crew cab with 173.4" wheelbase, 19,000 lb GVWR with 26,000 lb GCWR, Cummins I6 6.7 liter diesel with chassis cab tune 325 hp @ 2800 rpm and 750 ft-lb @ 1700 rpm, Aisin AS69RC 6-speed automatic, New Process NV271 manual transfer case, 14.5k lb Dana S14-111L limited slip and 7250 lb Magna Steyr 275mm with 4.44 ratios, Palfinger Badger low sill flat bed, Dual DeeZee 36x18x18 under bed boxes, Quad DeeZee 48x18x18 above bed boxes, Curt Double Lock 30K lb gooseneck, Dual 3/4" horse stall mats, SuperHitch Magnum 30K dual receiver with 42" SuperTruss, Upper StableLoads, Short range FastGun turnbuckles with locks
2018 Host Mammoth 11.5, Polarized dual pane windows, Powered and lit awning, Swing out Rieco-Titan jacks,  Fantastic Fan in cab over, Aero-Flo vent covers, 3x160w Zamp Solar with 30A controller, External 24" TV with DVD, Cargo slide tray, dual 6-volt batteries, 2.5KW LPG Onan, External LPG connection, 2-way water heater, Therford 3-burner cook top, Convection/Microwave, 8 cu ft 2-way Norcold Fridge, Loveseat with foot rest, U-shaped dinette, 1000W PSW Zamp inverter, King Jack amplified OTA antenna, 40" Samsung UN40J5200 smart TV in living room, Electric fireplace with heater, Accordion bedroom door, Full wall passenger-side cab over wardrobe, 32" Samsung UN32J5205 smart TV in Bedroom
#2 OFFLINE   stuwu4s
  • 744 posts
  • Local time: 01:19 PM
Posted 07 January 2018 - 03:41 PM
we went to the RV show in Greensboro, NC this past Friday, Senior day.  It was much smaller than Seattle of course. The wx here has been very cold, temp in the 20's and single digits at nites, so there was very little outside. A few units, but no one looked at them.
Inside it was mostly trailers. probably 75 percent trailers the rest motorhomes and 5th wheels. NO truck campers at all.
We have been to this RV show before and  there were a few TC's, outside.
  • 1365 posts
Posted 07 January 2018 - 04:57 PM
D&H in Apex seems to be good TC dealer in NC.
#4 OFFLINE   stuwu4s
  • 744 posts
Posted 07 January 2018 - 05:28 PM
we have been to D&H  many years ago. probably 150 miles from home. they were at the show. there probably was 8-10 dealers there. the  nearest one to us was about 35 miles away in Winston-Salem, NC. I bought a used 5er there 15 years ago.
