BAD WEATHER
20 replies to this topic
#1 OFFLINE   busfacebitbit
busfacebitbit
  • Local time: 08:50 AM
  • State/Province or Region:OHIO
  • Camper Brand:N/A
  • Truck Make & Model:2012 FORD F350 SRW
  • Name (Public):WILLIAM COWGAR
Posted 24 November 2017 - 03:00 PM
    I do have a question about what do you do when driving and encounters high winds. Try to find a spot to pull off , get off the next exit , or just pray and hope for the best? Or all of the above?
#2 OFFLINE   the tc life
  • 3754 posts
  • Local time: 11:50 PM
Posted 24 November 2017 - 05:35 PM
Depends on what you consider high winds are. 25 MPH? 50 MPH? 60+ MPH?
 I have no problem up to around 40 MPH winds, after that it can get a bet much for me. Over 50 is too dangerous for me and I will park it out of the wind somewhere if I can and wait it out.
 I have a dually with stiff suspension.
Posted 24 November 2017 - 09:54 PM
I avoid high gusts or hail, otherwise I just drive slower to meet conditions.
#4 OFFLINE   TDWebster
  • 103 posts
  • Local time: 02:50 AM
Posted 25 November 2017 - 06:35 AM
I generally just slow down to the point of my comfort level. I've never really been able to associate a "wind speed" just because i'm usually driving and the moment. Our 1T dually does a great job in the stability department. It really just depends on you, your time in the saddle and your individual setup.
#5 OFFLINE   Electrojake
  • 148 posts
Posted 25 November 2017 - 05:39 PM
Good point about wind speed...
When the wind gets strong enough to start blowing around damaging objects, I'm looking for shelter.
gmp_wind_oct_2017_tree-on-line-in-road-9
#6 OFFLINE   Camper_Jeff_&_Kelli
Camper_Jeff_&_Kelli
  • 321 posts
  • Camper Brand:S&S 9.5SC 2000 Model Year
  • Truck Make & Model:FORD F250 4x4
  • Name (Public):Jeff
Posted 25 November 2017 - 11:30 PM
Slow down. If you are not comfortable driving in high winds Pull off in a safe location. Don't park next to a tree, if you are already concerned about high winds, you should also avoid falling branches. If you can, point into the wind for a little more stability, less rocking while waiting for it to pass Make a sandwich or something and relax.
<img src='https://pqeo5g.bn1.l...humb.jpg?psid=1' alt='Posted Image' class='bbc_img' /><br />Tatoosh Island .5 miles offshore in the distance from Cape Flattery, the Northwestern tip of the lower 48 United States, the Olympic Peninsula, and Washington State, also the entrance to the Strait of Juan de Fuca and Puget Sound. Home of the Makah People.<br /><br />Visit Our Blog:<br /><a class='bbc_url' href='http://camperjeffandkelli.wordpress.com/'>http://camperjeffandkelli.wordpress.com/</a>
#7 OFFLINE   KnightEagle
  • Local time: 01:50 AM
Posted 26 November 2017 - 11:42 AM
I've been in winds where the TC is off center by 20 degrees its a white hand driving time. Out around El Paso Texas they can get some very high winds on a reg base's
#8 OFFLINE   Mr Firewood
  • Local time: 12:50 AM
Posted 27 November 2017 - 03:02 AM
Yeah, I've been in West Texas when the wind blows so hard it SUCKS.  When going east got better mileage.  Head back west it was still honking I had to give back my mpg and then some due to the headwind.
One trip back in 2007 I was traveling west on I-90 up over Snoqualmie Pass into Western WA towards Seattle.  Winds were predicted at 50-60 mph.  I was new to driving a vehicle with a truck camper on it and was towing my cargo trailer.  As I traveled toward the pass I found myself having to travel in the right lane with all the high profile vehicles, semis at 45 mph as the truck was pushing near 100 mph wind off the nose of the camper.   Between the vehicle speed and the head winds.  It was so bad I pulled off on 2 off ramps and checked to make sure all tires were inflated.  Once I crested the summit the wind was gone on the west side of the pass.
#9 OFFLINE   Bedlam
Posted 27 November 2017 - 08:07 AM
I had a similar experience with a moving truck years ago when I relocated from the SE to the NW. 45-50 mph top speed at 3-5 mpg thinking I was given a lemon of a truck until I talked to the truckers along my route.
#10 OFFLINE   busfacebitbit
busfacebitbit
  • Camper Brand:N/A
Posted 13 December 2017 - 12:26 PM
   thanks for the advice. Sorry it took so long to get back to you all. Wife had back surgery , and it's been a busy time at the old homestead. Slowly getting better Still a long recovery time.
#11 OFFLINE   Electrojake
  • 148 posts
Posted 14 December 2017 - 09:02 AM
Not a problem busfacebitbit. Life gets busy and I understand perfectly. . .
After 56 years of perfect health my wife (and co-pilot/navigator/camping partner) had minor surgery about 2 months ago and due to some unexpected complications she has been (for the first time in her life) pretty much incapacitated!
No more work, no more driving, no shopping, no camping, YIKES!
Man, I tell ya'; Life can change drastically in the blink of an eye.  :sign0175:
Best regards,
#12 OFFLINE   busfacebitbit
busfacebitbit
  • Camper Brand:N/A
Posted 18 December 2017 - 05:45 AM
    Unfortunatily my wife has had several surgeries. Hip replacement , lung cancer , almost died from septis , and now back surgery. Still hanging tough. Wife is concerned about holding up during long trips. Told her I could handle everything that needs done. Not ready to give up my one last dream just yet.
#13 OFFLINE   Electrojake
  • 148 posts
Posted 21 December 2017 - 09:32 AM
I didnt realize this head-wind issue could be that drastic but now that I think it over it certainly does make sense.
Thanks for the info on that!
#14 OFFLINE   Electrojake
  • 148 posts
Posted 21 December 2017 - 09:36 AM
    Unfortunately my wife has had several surgeries. Hip replacement , lung cancer , almost died from septis , and now back surgery. Still hanging tough.
You have a lot to deal with! Hope all goes well.
BTW, If my own situation doesnt improve soon I may be going to you for some advice.  :fing32:
Stay strong & thanks!
Best regards,
#15 OFFLINE   busfacebitbit
busfacebitbit
  • Camper Brand:N/A
Posted 22 December 2017 - 09:41 AM
  EJ , my advice is , it's okay to get angry with the situation , not the person. Other is find something to have hope with. Not a bible thumping church going guy. Do believe in a higher power whether God or just a super evolved intellect. pray and more prayer
#16 OFFLINE   Electrojake
  • 148 posts
Posted 22 December 2017 - 07:50 PM
Thank you for the kind advice.
Well spoken.  :)
#17 OFFLINE   busfacebitbit
busfacebitbit
  • Camper Brand:N/A
Posted 31 December 2017 - 04:32 AM
  my 92 year DAD just gave me his pride and joy. A 66 f100 mounted a 70 3/4 ton 4x4 chassis. Halfway home to being a happier camper . Definitely narrows down the options , but the price is right , both for the truck and the fact I can't buy a really big camper.
#18 OFFLINE   Electrojake
  • 148 posts
Posted 31 December 2017 - 12:12 PM
1.) . . . a  66 f100 mounted a 70 3/4 ton 4x4 chassis.
2.) I can't buy a really big camper.
1.) Post some pictures of that truck when time & weather permit!
2.) "Big" is not always best.
A small camper on little truck can be so much easier to live with than a massive beast. Especially here in the congested Northeast. Or so I've learned.
Good luck with the new 66 Ford and   :hny: in spite of this brutal weather.
#19 OFFLINE   sunliteowner
sunliteowner
  • 28 posts
  • Local time: 07:50 AM
  • State/Province or Region:indiana
  • Country:us
  • Camper Brand:sunlite
Posted 01 January 2018 - 03:24 AM
We purchased a 1993 sunlite a few years ago, wanted to make shure we  were going to be ok with it before committing a lot of money, good luck on the new to you rig, and watch those overhead low spots, best to avoid all drive through spots!
#20 OFFLINE   busfacebitbit
busfacebitbit
  • Camper Brand:N/A
Posted 06 January 2018 - 05:43 AM
  Actually don't have a camper yet. There is a few things that needs done to the truck before a put a camper on the back. As my dad aged , he let a few things go . Nothing major , truck runs fine and looks great. Just would like to upgrade to disc brakes and add power steering. Since weight now become a issue, does any one have a pop-up and what kind of issues do they have and would you consider another one or just go with something like the wolf creek or maybe a northern sportsmen. According to the tags on the 70 axles it should have a max payload of 3200 lb.
