Too Tall to Park in Garage
#1 OFFLINE   keelerwj
keelerwj
  • Local time: 06:19 AM
  • Camper Brand:Northstar TC650
  • Truck Make & Model:2008 F150 4x4
  • Name (Public):keelerwj
Posted 14 November 2017 - 10:43 AM
Greetings all, new guy here.
I bought a previously owned 2012 Northstar TC650 in August.  It fits nicely on my 2008 F150 4x4 with Torklift tie downs and fast gun turnbuckles.  I measured the garage door opening and confirmed that the camper would fit while loaded on the truck......wait for it....I failed to account for the fantastic roof vent.  First time camper owner, rookie mistake.  I'm not I'm not the first to do so.  Many of my very helpful friends and family have suggested the bits about cutting out the garage door header, trenching ruts in the cement floor, yada, yada, yada.  I currently unload the camper in the driveway onto a wooden cart, push it inside the garage and set the jacks to stabilize the camper.  A real pain, to say the least.
I need to reduce my truck and camper clearance the full extent of the fantastic fan (~4-5").  I'm about 5'10" tall, when the pop up camper is extended, I have ~9" head room between me and the vent.  Does anyone make a flush mounted fantastic roof vent?  Other suggestions?
Thanks in advance for your help.
  • 1381 posts
  • Local time: 10:19 PM
Posted 14 November 2017 - 11:42 AM
Deflate your tires before pulling into the garage?
2012 Interstate Car Carrier ICC10220TA3, 20'x8.5', 8" I-beam frame, dual 5200 lb 4" drop torsion axles, Diamond plate, Towmax 225/75R15 LRE tires on galvanized rims, Harbor Freight 10k lb equalizing hitch, Camping World vent cover, LED lighting, 3' RV door, front and rear door interior light switches, interior plywood walls and floor, 70' of Harbor Freight E-track rail with recessed corner 5k lb D-rings, Dual 42 gal fresh water tanks with Harbor Freight transfer pump, portable dual  Harbor Freight 45w solar arrays, 100 lbs LPG in four bottles, PowerArmor Max Solar 5-battery box, Deka 24HR3000 sealed batteries
2015 Ram 5500 HD 4wd Tradesman 60" CA, Crew cab with 173.4" wheelbase, 19,000 lb GVWR with 26,000 lb GCWR, Cummins I6 6.7 liter diesel with chassis cab tune 325 hp @ 2800 rpm and 750 ft-lb @ 1700 rpm, Aisin AS69RC 6-speed automatic, New Process NV271 manual transfer case, 14.5k lb Dana S14-111L limited slip and 7250 lb Magna Steyr 275mm with 4.44 ratios, Palfinger Badger low sill flat bed, Dual DeeZee 36x18x18 under bed boxes, Quad DeeZee 48x18x18 above bed boxes, Curt Double Lock 30K lb gooseneck, Dual 3/4" horse stall mats, SuperHitch Magnum 30K dual receiver with 42" SuperTruss, Upper StableLoads, Short range FastGun turnbuckles with locks
2018 Host Mammoth 11.5, Polarized dual pane windows, Powered and lit awning, Swing out Rieco-Titan jacks,  Fantastic Fan in cab over, Aero-Flo vent covers, 3x160w Zamp Solar with 30A controller, External 24" TV with DVD, Cargo slide tray, dual 6-volt batteries, 2.5KW LPG Onan, External LPG connection, 2-way water heater, Therford 3-burner cook top, Convection/Microwave, 8 cu ft 2-way Norcold Fridge, Loveseat with foot rest, U-shaped dinette, 1000W PSW Zamp inverter, King Jack amplified OTA antenna, 40" Samsung UN40J5200 smart TV in living room, Electric fireplace with heater, Accordion bedroom door, Full wall passenger-side cab over wardrobe, 32" Samsung UN32J5205 smart TV in Bedroom
#3 OFFLINE   TDWebster
  • 97 posts
  • Local time: 01:19 AM
Posted 14 November 2017 - 04:00 PM
Maybe check into air bag coils for truck to replace coil springs, allowing you to lower the truck further (like a low rider---sort of). Or add a knee wall to the garage, if its not attached to the house and add a panel to the garage door----extreme in the least, but doable
#4 OFFLINE   ARSMITH
ARSMITH
  • 68 posts
  • Local time: 12:19 AM
  • State/Province or Region:Alabama
  • Interests:Motorsports & Classic Cars.
  • Camper Brand:PALOMINO BRONCO 1500
  • Truck Make & Model:2004 Chevrolet 3500 Duramax
  • Name (Public):ANDY SMITH
Posted 14 November 2017 - 05:56 PM
I have been loading/unloading and setting my camper on a metal table on the driveway and rolling it in & out of my carport for years. My previous truck/ camper combo fit the carport fine, my current truck w/camper will not.
Each time I go camping I dream of a garage/ carport that my truck & camper fits into without the added hassle.
Andy :)
Edited by ARSMITH, 15 November 2017 - 01:37 AM.
#5 OFFLINE   busfacebitbit
busfacebitbit
  • 13 posts
  • State/Province or Region:OHIO
  • Camper Brand:N/A
  • Truck Make & Model:2012 FORD F350 SRW
  • Name (Public):WILLIAM COWGAR
Posted 16 November 2017 - 01:48 AM
  Could put on smaller wheels and tires. Wouldn't  try it with a heavy camper unit , but for a light weight unit might be okay option. I remember  when pick-ups came with 15's and 16's as an option.
