SWITCH
camper switch
#1 OFFLINE   fourkoals
fourkoals
  • Local time: 09:47 PM
  • State/Province or Region:wa
  • Camper Brand:fleetwood
  • Truck Make & Model:ford
  • Name (Public):lee
Posted 10 October 2017 - 09:09 AM
We have this switch near the kitchen sink of our 2002 Caribou camper. We have no idea what it's for. Previous owner could not figure it out. He was able to trace it to the battery. You can see it in this picture. To the right of the blinds.
Edited by fourkoals, 10 October 2017 - 10:39 AM.
#2 OFFLINE   stuwu4s
  • 759 posts
  • Local time: 04:47 PM
Posted 10 October 2017 - 10:19 AM
what picture??
picture is now appearing - thanks
as a guess, might be water pump switch. this a pure "swag".
or light switch.
based on its location.
#3 OFFLINE   Rick Johnson
Rick Johnson
  • 370 posts
  • Local time: 02:47 PM
  • Camper Brand:2007 Lance 1181
  • Truck Make & Model:2019 Ford F-350 XLT Crew Cab DRW
  • Name (Public):Rick Johnson
Posted 16 October 2017 - 06:44 PM
Battery disconnect?
2004 F-350 Crew Cab 4WD Dually w/ Airlift air bags, Luverne brush guard, side steps and splash guards.
2007 LanceMax 1181 with nearly every option, enlarged cabover space (driver's side locker omitted), wider custom mattress.
  • Local time: 01:47 PM
Posted 16 October 2017 - 08:46 PM
Exterior light on the left side of the TC?
#5 OFFLINE   RichConley
  • 2155 posts
Posted 17 October 2017 - 06:22 AM
Garbage disposal?  No, what he said - outside light?
Posted 17 October 2017 - 11:58 AM
Think Bedlam is right. We have a switch on our instrument panel in the Adv it controls the entry light above the door inside yet all you need to do is reach above you to turn the light on. I lean towards that idea its a power switch for the side light where it may have a on-off there on the light.
