Alternative fresh water tank drain
#1 OFFLINE   lat
lat
  • Local time: 02:34 PM
  • State/Province or Region:New York
  • Camper Brand:Northstar
  • Truck Make & Model:Chevy Silverato
  • Name (Public):Lee
Posted 31 August 2017 - 06:08 AM
Have a Northstar TC that drains the fresh water tank straight down through the floor onto the ground when off the truck. Has anyone retrofitted a way to drain while leaving on the truck. Would prefer not to dump the water in the truck  bed  for obvious reasons. Really don't want to run the pump constant to drain through the sink and grey water tank. Thanks  Lee
  • Local time: 07:34 AM
Posted 31 August 2017 - 11:21 AM
Without seeing your TC or even knowing which model it is. I take a stab at it. You are say draining out the bottom in to the bed I can see the set up in my mind. Maybe the line going to your pump just before it gets to the pump install a tee will a shut of valve and a water hose connection and cap. Still have water to the TC all the time yet the shut off only affects the hose connection. In my trailer I have extra water tank and a gray tank. There I have two 12v pumps one for each tank. With the 12v pump you could hook up a hose from the TC connection to the pump and just pump it out, just make sure you have the water fill open or you could flatting your tank. I got the pump at homedepot online, Cost wasn't that much. just a stab at it.
#3 OFFLINE   Stan
  • Local time: 06:34 AM
Posted 10 September 2017 - 07:50 PM
I'm also looking for a simple solution.
#4 OFFLINE   Lancealot
Lancealot
    lancealot
  • 585 posts
  • Interests:TCing , fly fishing , drag racing ,
  • Camper Brand:Lance 1010
  • Truck Make & Model:2000 f-550 XLT crew/4x4
  • Name (Public):Brian
Posted 10 September 2017 - 08:01 PM
Is it possible to get access to the drain pipe on the outside of TC , if so maybe run an extension pipe past the TC to back end of truck box and let the water flow to the ground .Our
Lance has a drain pipe at the rear compartment on the driver's side . I just open the access door and let the water drain to the ground . Hope this helps you . Brian
CAMPING  where you spend a small fortune , to live like a homeless person .
#5 OFFLINE   TDWebster
  • 100 posts
  • Local time: 09:34 AM
Posted 16 September 2017 - 03:36 AM
I recently had the bottom of our AF 990 out, and was able to see for myself how everything was plumbed, the freshwater outside drain is just piped from the back of the tank to the rear area and a valve installed near the greywater/ blackwater drain area, then through the bottom, allowing all drain operations while on the truck. Removal of the bottom in my case would be the only real way of a good modification to the system.
#6 OFFLINE   lat
lat
  • Name (Public):Lee
Posted 16 September 2017 - 08:09 PM
Thanks for the replies. With the camper off the truck I was able to get under and drill holes for tubing to be fed from the original drain back to the rear of the camper. Then I attached the tubing to the end of the valve sticking down through the floor with a compression fitting. Used a cable clamp to keep it from bending too far and kinking the tube as it turned.
Appreciate the suggestions. Lee
