19.5 inch wheels
#1 OFFLINE   Jillneddie
Jillneddie
  • Local time: 07:28 PM
Posted 29 August 2017 - 08:57 AM
Considering going from Af992 to host Cascade. Doing research on what I have to do to carry the Cascade on a srw GMC 3500. Carries the af fine with stable loads and Heavy duty Timbrens. If I have to change from 18 inch wheels to 19.5 how much will that effect mileage and speedometer? Do g rated tires come in 18 inch or is that just 19.5. Hoping that current set up will work but may not. The Cascade is only minimally heavier than the 992.
#2 OFFLINE   fredandjoann
fredandjoann
  • 19 posts
  • State/Province or Region:Missouri
  • Camper Brand:2017 Host Rainier SB
  • Truck Make & Model:2015 Ford F450 Lariat 6.7 PSD CC 4X4
  • Name (Public):Fred
Posted 29 August 2017 - 10:39 AM
Earlier this year I was working on replacing wheels on my then F350 SRW truck from 18" to 19.5".  The tires for the 19.5" wheels have shorter side wall height so the overall diameter was going to be the same, therefore, no change in speedometer.  I didn't finish that change as I instead traded trucks for an F450 that already had 19.5" wheels.
  • Local time: 05:28 PM
Posted 29 August 2017 - 11:39 AM
275/70R18 tires were the same height as my 245/70R19.5 replacements (about 33" tall). I suggest going with LRH or PR16 tires even if you don't that much capacity - You can run less air pressure in them than a LRG/PR14 tire to get the same weight carrying.
#4 OFFLINE   Jillneddie
Jillneddie
Posted 29 August 2017 - 07:20 PM
Tks for info. Bedlam what the difference in the tires you mention. I'm obviously a novice on these types of tires.
#5 OFFLINE   Bedlam
Posted 30 August 2017 - 04:35 AM
These tires and rims are heavier allowing for their greater capacity. Expect each mounted wheel to weigh about 125 lbs, upgrading to heavier dampening shocks like the Bistien or Rancho will help keep that additional unsuspended weight in control. You have a choice of 4500 lb rated Vision, 5000 lb rated Rickson and 6000 lb rated American Force 19.5" rims. There are plenty of 245/70R19.5 tires available, so you will need to choose your favorite brand or tread pattern.
The tires can only be aired down to about 70 psi due to a different style of bead on the rim and tire. This makes them a poor choice in soft sand or deep snow where you need flotation on top of the material rather than digging down. However, they do well in other traction applications. Since this tire has less flex than an LT tire, the unloaded ride will be a little harsher, but not any worse than low profile sport car tires. When loaded, these tires will show their merits - They will flex less under load giving you a more confident ride and handling.
#6 OFFLINE   dvanceman
dvanceman
  • 10 posts
  • Local time: 06:28 PM
  • Country:united states
  • Interests:camping, fishing, biking,kayaking,gardening,
  • Camper Brand:northernlite,2012
  • Truck Make & Model:dodge ram 3500,long box
Posted 31 August 2017 - 03:49 AM
I found the spedo to be 5mph off you can use a gps unit. I found this to be true using my garmin. The ride is deintely rough without camper on truck I would rather be on the safe side.
