6volt vs 12 volt
#1 OFFLINE   Jillneddie
  • Local time: 10:13 PM
Posted 05 August 2017 - 05:07 PM
Got a quote on a host Cascade. Option is 2 6 volt batteries or 2 standard 12 volt deep cycle. What are the advantages of 6 vs 12?
  • 1387 posts
  • Local time: 08:13 PM
Posted 05 August 2017 - 10:23 PM
6vdc batteries typically have thicker plates allowing heavier charge and discharge than the thinner plates of a 12vdc battery.
<p><span style="color:#a9a9a9;"><strong><span style="font-family:tahoma, geneva, sans-serif;"><span style="font-size:10px;">2012 Interstate Car Carrier ICC10220TA3, 20'x8.5', 8" I-beam frame, dual 5200 lb 4" drop torsion axles, Diamond plate, Towmax 225/75R15 LRE tires on galvanized rims, Harbor Freight 10k lb equalizing hitch, Camping World vent cover, LED lighting, 3' RV door, front and rear door interior light switches, interior plywood walls and floor, 70' of Harbor Freight E-track rail with recessed corner 5k lb D-rings, Dual 42 gal fresh water tanks with Harbor Freight transfer pump, portable dual Harbor Freight 45w solar arrays, 100 lbs LPG in four bottles, PowerArmor Max Solar 5-battery box, Deka 24HR3000 sealed batteries </span></span></strong></span></p>
<p> </p>
<p><span style="color:#a9a9a9;"><strong><span style="font-family:tahoma, geneva, sans-serif;"><span style="font-size:10px;">2015 Ram 5500 HD 4wd Tradesman 60" CA, Crew cab with 173.4" wheelbase, 19,000 lb GVWR with 26,000 lb GCWR, Cummins I6 6.7 liter diesel with chassis cab tune 325 hp @ 2800 rpm and 750 ft-lb @ 1700 rpm, Aisin AS69RC 6-speed automatic, New Process NV271 manual transfer case, 14.5k lb Dana S14-111L limited slip and 7250 lb Magna Steyr 275mm with 4.44 ratios, Palfinger Badger low sill flat bed, Dual DeeZee 36x18x18 under bed boxes, Quad DeeZee 48x18x18 above bed boxes, Curt Double Lock 30K lb gooseneck, Dual 3/4" horse stall mats, SuperHitch Magnum 30K dual receiver with 42" SuperTruss, Upper StableLoads, Short range FastGun turnbuckles with locks</span></span></strong></span></p>
<p> </p>
<p><span style="color:#a9a9a9;"><strong><span style="font-family:tahoma, geneva, sans-serif;"><span style="font-size:10px;">2018 Host Mammoth 11.5, Polarized dual pane windows, Powered and lit awning, Swing out Rieco-Titan jacks, Fantastic Fan in cab over, Aero-Flo vent covers, 3x160w Zamp Solar with 30A controller, External 24" TV with DVD, Cargo slide tray, dual 6-volt batteries, 2.5KW LPG Onan, External LPG connection, 2-way water heater, Therford 3-burner cook top, Convection/Microwave, 8 cu ft 2-way Norcold Fridge, Loveseat with foot rest, U-shaped dinette, 1000W PSW Zamp inverter, King Jack amplified OTA antenna, 40" Samsung UN40J5200 smart TV in living room, Electric fireplace with heater, Accordion bedroom door, Full wall passenger-side cab over wardrobe, 32" Samsung UN32J5205 smart TV in Bedroom</span></span></strong></span>
#3 OFFLINE   Chief 2
  • 53 posts
  • State/Province or Region:Florida
Posted 06 August 2017 - 02:16 AM
If you plan on doing a lot of boon docking go with the deep cycle 6v batteries and solar. You won't regret it.
#4 ONLINE   Mr Firewood
  • 459 posts
Posted 06 August 2017 - 03:18 PM
12's are cheaper that's for sure.  We recently put 4 six volts in our 5'er.  About double the price per battery times four for 4 six volt golf cart batteries.  But we have a ton of solar on the trailer roof.  Three 160 watt panels.  Next upgrade will be a good size inverter.   Thinking 4,000 watts.
In our truck camper we have 2 Group 29's and 80 watts solar on the roof.  (Not so effective in the winter when there is 2+ feet of snow on the campers roof)  Keeps the lights and furnace ignitor & fan operational.
#5 OFFLINE   Squish
  • 7 posts
  • Local time: 04:13 AM
  • State/Province or Region:Ca
Posted 13 August 2017 - 10:23 PM
When you have two 6v wired up as a 12v battery you have a much larger storage of power.
But it comes at a cost, the 6v batteries are heavier.
We got a good price on our 6v golf cart batteries from that big box retail chain based in Kirkland wa.
They were only about $20 more per battery vs the group 24 12v ones they replaced.
We mostly boondocks and really needed the extra power in reserve.
  • Local time: 09:13 PM
Posted 14 August 2017 - 06:16 AM
I just had to replace both of my batteries after one exploded in the TC. It basicly shorted out inside its self. the ones I put back after repairs were two group 29's marine batteries. And two extra our on the trailer for four of them.
