Hookup camper to truck
#1 OFFLINE   digitaldiver
digitaldiver
  • Local time: 02:20 AM
  • State/Province or Region:Florida
  • Name (Public):digitaldiver
Posted 26 July 2017 - 04:58 AM
Hi All, how does the camper hookup electrically to the truck? does the truck just need a tow package? Does the camper have an electrical cord you then connect to the truck where the electrical socket on the toes hitch is?
Thanks
Edited by digitaldiver, 26 July 2017 - 04:59 AM.
#2 OFFLINE   Mr Firewood
  • Local time: 07:20 PM
Posted 26 July 2017 - 02:34 PM
Normally a 2nd electrical outlet is wired into the side of the trucks bed near the left front.  Note that Lance campers use a special plug.  Yes the camper will have a 4-5 cord with plug that corresponds to the outlet you wire into the trucks bed.
I have 3 outlets at the left front of my trucks bed.   One for the camper, one for the back up camera on the camper and one for my 5th wheel trailer.  Since like I said above Lance uses a different electrical connector thus I have to have two types in my bed plus the outlet for the camera to the cab.
I don't know if Lance still builds with the wonky plug system as my truck and camper are from back in 2006.
#3 OFFLINE   PACK4TAG
PACK4TAG
  • Local time: 09:20 PM
  • State/Province or Region:IA -AZ
  • Camper Brand:2001 825 LL EC Lance
  • Truck Make & Model:15 FORD 250 BRONZE GAS W/TAG
  • Name (Public):Roy
Posted 26 July 2017 - 05:33 PM
Still Wonkey
#4 OFFLINE   Mr Firewood
Posted 26 July 2017 - 05:52 PM
​What's Wonkey Roy?  Oh, the Lance plugs.  Just dawned on me from what I wrote.  Since I see you also own a Lance.
#5 OFFLINE   Bedlam
Posted 26 July 2017 - 06:45 PM
Both my Arctic Fox and Host use the standard 7-blade trailer connector. My cords run to the rear plug next to the truck receiver and neither of my trucks needed in-bed outlets.
#6 OFFLINE   69Bronco
69Bronco
  • 33 posts
  • State/Province or Region:AZ
  • Camper Brand:Pilgrim (Early 80's)
  • Truck Make & Model:1997 Ford F-350 Crewcab 4x4 Powerstroke
  • Name (Public):Ryan
Posted 05 September 2017 - 11:02 PM
My antique Pilgrim TC used a 6-pin round connector at the front driver side that would have connected to an in-bed plug. I chopped it off, added some wire, and now it plugs into the 7-way RV plug next to my trailer hitch.
Truck: 1997 Ford F-350 Crew Cab 4x4 7.3l Powerstroke turbodiesel, manual transmission, 3.55 limited slip front and rear. Performance: RiffRaff 6637 cold air intake, rebuilt turbo with Wicked Wheel compressor, Diamond Eye 3" downpipe and 4" cat-delete, Tony Wildman 6 position chip (economy, daily driver, light tow, heavy tow, race, extreme), 6.0l intercooler with custom handmade piping. Equipment: Torklift original Superhitch, Torklift frame-mounted tie-downs, front brushguard, home-brew towing mirror extenders, home-brew "stable-loads".
Camper: Early 80's Pilgrim 8.5' TC (exact vintage unknown). Queen size cabover, 2-way gas-electric fridge, gas oven and range, wet bath with toilet and hand shower, hot water heater, 4" basement containing freshwater tank, grey- and blackwater tanks, vintage Recair swampcooler on the roof, household air conditioner retrofitted into the rear window. Plumbing completely replaced with PEX and accumulator and check valve added. Repaired, reinforced, re-plumbed, re-sealed, re-painted, re-upholstered, and EVERYTHING WORKS!!!
#7 OFFLINE   Wellsdesigned
Wellsdesigned
    Senior (in title, not age) Camper
  • 648 posts
  • Interests:Camping
    Traveling
    Molding My 10 Acres
    Writing
    Architecture
  • Camper Brand:Eagle Cap 850 w/ slide
  • Truck Make & Model:2002 Chevy 2500 HD
Posted 21 September 2017 - 05:24 AM
I had a bed connector. It was a pain to remember to plug it in before lowering the camper and remembering to remove it before pulling out.  I got a longer chord to run from the camper to the trailer hitch plug.  Now I plug in after putting the camper on the truck and I have time to remember to unplug while pulling out from under it.
Based above the Sacramento CA fog/smog
2002 2500HD 4X4 Ext. Cab 6.0L
2004 Eagle Cap 850 TC w/slide-out
My creative writing Website
