Does anyone have solar on Northern Lite 811?
#1 OFFLINE   TCINTN
TCINTN
  • 227 posts
  • Local time: 08:23 AM
  • State/Province or Region:Tn
  • Interests:Trout Fishing and Grand kids
  • Camper Brand:Northern Lite 811
  • Truck Make & Model:2006 Dodge 3500 Mega Cab SRW Laramie
Posted 02 July 2017 - 06:12 PM
Thinking about putting solar on our Northern Lite 811 and was wanting to see if there is someone with an 811 who has done so.
If so,where did you put panels,how many,and do you have pictures?
Thank you
tcintn
2006 Dodge 3500 Mega cab SRW
Soon to have Outfitter Apex 8
#2 OFFLINE   Wanky
  • 186 posts
  • Local time: 01:23 PM
Posted 07 July 2017 - 07:23 PM
  • Local time: 12:23 PM
Posted 08 July 2017 - 08:18 AM
Mine is not a NL, but I have two panels on the cab over section and one along side the air conditioner. It would be easy to glue mounts on your NL rather than drill mounting holes for your panels. If you have the unit prewired for solar, you can connect all the panels before going to a single connection plug. If you do not have wiring in place the easiest way to get inside is through the refrigerator vent. MPPT controllers are more efficient but more costly - If you go with one of these, you would wire your solar panels in series to boost the voltage and reduce the amperage. This give you less line loss and the ability to run thinner wire than when pushing higher amperage.
