Off-truck TC cover
cover truck camper UV
#1 OFFLINE   Turner Luce
Turner Luce
  • 9 posts
  • Local time: 08:19 AM
  • Camper Brand:TBD
  • Truck Make & Model:TBD
  • Name (Public):Turner Luce
Posted 30 May 2017 - 08:53 PM
I need to cover my new Northern Lite 10 2 EXCD and found the cover below. Are you familiar with it or have a better suggestion?
https://www.amazon.c...VGHQEKD7VVX17JN
Thanks! TL
#2 OFFLINE   RichConley
  • 2133 posts
  • Local time: 07:19 AM
Posted 31 May 2017 - 04:40 AM
Not familiar with it.  But the Amazon reviews seem about on par with the Adco cover.
I've used the Adco and will probably stick with it unless I can get a really good deal on it.
#3 OFFLINE   Turner Luce
Turner Luce
  • 9 posts
  • Camper Brand:TBD
Posted 31 May 2017 - 08:42 PM
Thanks Rich
#4 OFFLINE   Rick Johnson
Rick Johnson
  • 370 posts
  • Local time: 09:19 AM
  • Camper Brand:Lance 1181
  • Truck Make & Model:2004 Ford F350 Crew Cab dually
  • Name (Public):Rick Johnson
Posted 01 June 2017 - 07:25 PM
I have the larger version for my 11'6" Lance. It has lasted two winters and might make a third. Trouble is, any part that sticks out, like the rear jacks, rub and rub in any wind and wear thru the fabric. I've become quite accomplished at placing thin foam packing material strategically to try to prevent this. When It does  wear thru, I have found that Gorilla Tape (I prefer white) can last a season as well. I also use extra rope to tie around the cabover as close to the rear as possible and around the waist line at about the top of the jacks. If there is a possibility that a rope will rub, I reinforce strategically with Gorilla tape.
I also cover all the plastic vents with soft fabric or rugs tied in place to prevent rubbing and I put a piece of carpet on the folded down Sat dish. Radio antenna comes off as well.
Wind is the ENEMY.
2004 F-350 Crew Cab 4WD Dually w/ Airlift air bags, Luverne brush guard, side steps and splash guards.
2007 LanceMax 1181 with nearly every option, enlarged cabover space (driver's side locker omitted), wider custom mattress.
