Can my truck do it?
Amerigo weight help newbee crazy
8 replies to this topic
#1 OFFLINE   sweeney153
sweeney153
  • Local time: 09:44 AM
  • Camper Brand:coachman
  • Truck Make & Model:chevy 1500 4x4
  • Name (Public):Kevin Sweeney
Posted 04 May 2017 - 05:48 AM
I have found the camper i really want. It's a 1979 amerigo with the nap.
Now the problem. My truck is a 2006 Chevy 1500 4X4 regular cab 8' bed. I don't know how much it weighs. My truck has a payload capacity of 1900 pounds. I may have to beef up the suspension or get a bigger truck, but i can't do that before i have to pick it up. It's 3 1/2 hours drive from home. Can i do it or am i crazy?
Anyone have another idea to pick it up? My son suggested a uhaul trailer.
I am looking forward to you  words of wisdom.
  • 1947 posts
  • Local time: 07:44 AM
Posted 04 May 2017 - 07:44 AM
borrow a flat trailer or a 3/4 ton
  • Local time: 06:44 AM
Posted 04 May 2017 - 08:53 AM
If you use your truck or borrow one, you will need to think about how the camper will be tied down to it. If you use a trailer, tie downs will be easier but you will want a trailer that is narrower like the width of a SRW truck unless the camper has front swing out brackets - It may be hard to find a narrow trailer with enough payload to carry the camper.
#4 OFFLINE   Oliver
  • Local time: 08:44 AM
Posted 04 May 2017 - 09:06 AM
Well, where are you, and where is the camper? Don't try to carry it with your 1500.
#5 OFFLINE   sweeney153
sweeney153
Posted 04 May 2017 - 10:15 AM
"Well, where are you, and where is the camper? Don't try to carry it with your 1500. "
I am in orange county NY and the camper is in Rhode Island about 3 1/2 hours
#6 OFFLINE   Oliver
Posted 04 May 2017 - 11:14 AM
That's a bit too far down the road for comfort, or I'd offer to help you get it home. I still wouldn't put it on a 1500. It might carry it, but all your margins of safety would be gone.
#7 OFFLINE   KnightEagle
  • 1947 posts
Posted 05 May 2017 - 08:14 AM
Maybe they deliver it for a small fee?
#8 OFFLINE   atchafalaya_man
  • 1583 posts
Posted 09 May 2017 - 06:55 AM
Payload included the weight of you and your passenger, plus anything else you are carrying in the cab of the truck.  Subtract that and the weight of a camper you can carry shrinks by that much.
#9 OFFLINE   Norske
  • 216 posts
Posted 10 May 2017 - 06:07 AM
1/2T pickups are little more than cars with boxes.  They are okay for hauling lawn/garden waste or an appliance, or towing a boat.  They are built for commuting, not for hauling heavy loads.
Also tagged with one or more of these keywords: Amerigo, weight, help, newbee, crazy
