NorthStar 950sc height
#1 OFFLINE   Jswharton
Jswharton
  • Local time: 06:00 AM
  • State/Province or Region:TX
Posted 03 May 2017 - 10:49 AM
Can't seem to fine the max height of a northstar 950sc with AC, loaded on a 2011 Superduty DRW in travel mode. Any approximations? Thinking it would be under 11' but not sure
  • 1418 posts
  • Local time: 10:00 PM
Posted 03 May 2017 - 11:21 AM
It is roughly 6.5' from the load floor to a high profile air conditioner with the top stowed. Add your bed height of about 3' and overall height should be 9-10' high from my calculated wag.
#3 OFFLINE   Jswharton
Jswharton
Posted 03 May 2017 - 02:25 PM
perfect, thanks was hoping for under 10'.  i
