What to do?
22 replies to this topic
#1 OFFLINE   KnightEagle
  • Local time: 02:05 AM
Posted 10 April 2017 - 08:28 AM
Been thinking of getting a new TC. Went to ProncessCraft to kick the doors so to speak. Looked at the EC-1200 it looks better on the web than in person I thought. But over all I liked it, yet the shower pan I saw a big flaw. Dont move to much or yhe curtain will be pushed out and water could get out on the floor. Yet the EC-1200 and EC-1165 both are pushing 5800 wet. Yet the Host Mammoth was in the running same fault 5600+. They needed a diet, Then along comes Adventure 116 DS pushing in near 5000 wet even with the weight of the trailer hitch I'm just a little over my limit. What to do or can I ???
#2 OFFLINE   Mr Firewood
  • Local time: 01:05 AM
Posted 10 April 2017 - 12:11 PM
Buy a bigger truck or a smaller/lighter camper. When I bought my Lance 1191 back in 2006 no 1 ton's being built could handle the campers weight. So I bought an F-550 which handles the camper very nicely.
1st you pick a camper, then you buy a truck that will haul it, then you buy the camper.
Good Luck on your search.
George
  • Local time: 12:05 AM
Posted 10 April 2017 - 04:52 PM
That's what I had to do. I could not afford to do this all at once, so my little Arctic Fox 811 was carried on my Ram 5500 for two years until I could save up for the Host Mammoth.
Posted 10 April 2017 - 06:21 PM
Just on payload alone the Adv 116 DS and the tongue weight of my trailer I'm a little over. Do have a weight distribution hitch on the trailer. It would take all the tricks to be ok and that may put me over by 200lbs
#5 OFFLINE   Bedlam
Posted 10 April 2017 - 07:52 PM
Your AAM axle is rated for about 11K lbs and your rear wheel capacity is north of 10K lbs. What does the truck rear weigh when empty, 3500 lbs? You should have about 6500 lbs of rear payload capacity. At that weight you may need to add more leaf springs and heavier dampened shocks, but not much else.
#6 OFFLINE   the tc life
  • 3755 posts
Posted 11 April 2017 - 05:22 AM
Ahhh, the Adventurer 116DS is the camper we would love to get. No step up to the slides, the floor level is over the bed rail. Not even much of a step up into the cab over with the king sized bed. All that holds us back is...money.
#7 OFFLINE   KnightEagle
Posted 11 April 2017 - 07:11 AM
Your right Pete with the setup I have could handle the Adventure the best. At 5133lbs wet then gear, food and tongue weight I can do it. The 1165 wet weight is at 6034 by the time I got to the trailer tongue I be hitting 8k.
#8 OFFLINE   KnightEagle
Posted 11 April 2017 - 01:19 PM
Pulled the triger we are in the process of trying to purchase the Adventure 116 DS its located on the east coast looks like a road trip and a vacation for the wife I plan on being retired by then.
#9 OFFLINE   Bedlam
Posted 11 April 2017 - 03:14 PM
When will you get it? Are you going to order it like you want or did you find a deal? My Host should be getting carted out of production soon.
#10 OFFLINE   KnightEagle
Posted 12 April 2017 - 07:04 AM
Financing has to go through first, had to move on it found others but as soon as I found them they sold that fast. Or they low balled on the trade-in. Yes that's how they make there money. But not on me, the replacing of the roof was more than they offered at on dealer in Idaho. Then I found two at once a 2016 and a 2017 liked the 16 but when I went back they had sold it. Yet the 17 had all the bells and then some.Attached File  116DS6ds00001.JPG   57.45KB   0 downloads
#11 OFFLINE   Chrome20
Chrome20
  • Local time: 08:05 AM
  • State/Province or Region:Nevada
  • Name (Public):Tony
Posted 12 April 2017 - 08:05 AM
The interior looks nice.
#12 OFFLINE   Oliver
  • Local time: 03:05 AM
Posted 23 April 2017 - 07:55 AM
Congrats on the new camper! Where is it located on the east coast?
#13 OFFLINE   KnightEagle
Posted 31 August 2017 - 11:35 AM
Well the deal on the Adv 116DS back east fell apart couldnt come to terms. So close but you know it only counts in horse shoes and hand grenades. Didn't stop us, on the 18th next month will be picking up the new 116Ds TC in Lewiston, ID. Will be seeing my sister in Boise first.
#14 OFFLINE   the tc life
  • 3755 posts
Posted 05 September 2017 - 05:05 AM
You know...Lewiston is not far from the Spokane area. Lol. We work during the weekdays though.
#15 OFFLINE   KnightEagle
Posted 05 September 2017 - 10:51 AM
only saw a note saying tc-life quoted you need to pay my dues just cant find the link and for the last week there been no new posts?????
#16 OFFLINE   the tc life
  • 3755 posts
Posted 05 September 2017 - 07:06 PM
Private message sent.
#17 OFFLINE   KnightEagle
Posted 24 September 2017 - 04:39 PM
Well this has been a Adventure for sure. Pulled out last saturday to head up to Idhao when we got a call from RnR on the Adv 116DS They said bring the title I responded your lucky we still have the reciet showing the purchase back in 2012. Got to have the title to take it as trade. WHAT A TITLE we dont have titles in Texas. Got to have one, dont think they take the bill of sale they said want know till monday, WHAT! You can come on up and we will see monday. The **** you say just how in the **** would I get both back home if you dont take it. It was all ready for the trip loaded and 20 miles from home. Made some calls and found the one in OHIO was still for sale. Told them it was sold and we be there monday. It was fully loaded all the bells and whisles and 8k more but its ours!!! The old AF-990 just fell apart ref died on the way the geney died only got 4k but cant win them all fig ref and geney was 4k if i replace them will post the picture of it on the truck. Are at a lake outside of Apex NC. Loss of 110 from the geney and have there techs waiting for us monday.
#18 OFFLINE   the tc life
  • 3755 posts
Posted 25 September 2017 - 04:22 PM
So if I understand that right...you did not get the one in Clarkston Washington then?
#19 OFFLINE   KnightEagle
Posted 28 September 2017 - 11:41 AM
No they wanted us to head up not knowing if they could or could not buy the AF-990 because all we had was a bill of sale from Tom's Camper Land. So we knew that in Ohio there was one with all the goodies on it. and 8k more. Sence we were already on the road did a u-turn and head north east. We were still in San Antonio so the change of direction was no big deal. So far we just love the TC even for its not to good of thought of some items. 1) there are three and a half 110 outlets. 2) only one 12v plug 3) No USB outlets at all. 4) and the biggest of all the generator is under sized for this size camper it should have a 4000 watt gen.  I will explane the problem you can have the A/C-on ref-on that's it want the coffee pot on put the ref on propane cross your fingers that the gen don't trip. Or Want toast agin switch the ref to propane can then make toast. Want to have microwave popcorn put everything on propane switch off the A/C then you can have the popcorn and make your toast and have a cup of joe. Yet on shore power everything works great. I've already told Adventure they should have installed the onan 4000 its about 10% larger and 115 lbs heaver sure it can be converted to propane as the 2500 is. So the first upgrade I have to do at home is install the 5000 watt envert thats in my garage at home there I can run plugs out to the kitchen for the coffee pot/ref/micrwave then on the island a plug for the Ice maker or toster
#20 OFFLINE   Bedlam
Posted 28 September 2017 - 01:01 PM
If you have dedicated outlet runs to your inverter, you can definitely balance the load out. Plugging in your counter top appliances into the inverter will work whether you run the generator or are on shore power. In my camper, there are three outlets powered by a PSW 1000w inverter allowing me to use regular AC powered TV's and run my cellular/WiFi hotspot.
My on board Onan has no problem running the convection/microwave while running the air conditioner, but you probably have a different size and model AC. You may be able to add a soft start kit to the your AC to make things work better.
As you pointed out, running the fridge on electric while running the generator takes away some of the capacity - Also make sure you do not have the electric water heater element turned on.
