19.5" wheels
9 replies to this topic
#1 OFFLINE   fredandjoann
fredandjoann
  • 20 posts
  • Local time: 01:39 AM
  • State/Province or Region:Missouri
  • Camper Brand:2017 Host Rainier SB
  • Truck Make & Model:2015 Ford F450 Lariat 6.7 PSD CC 4X4
  • Name (Public):Fred
Posted 28 March 2017 - 10:19 AM
Back in January I ordered a set of Rickson wheels for our 2011 F350 SRW and was given an end of March possible delivery date.  Now they are saying a few more weeks.  I liked the Ricksons because they were a match to our existing wheel lug pattern and offset.
Does anyone have a good alternate solution?
  • 1417 posts
  • Local time: 11:39 PM
Posted 28 March 2017 - 11:40 AM
Vision 81A Heavy Hauler are aluminum in silver or black and rated for 4500 lbs each
http://www.visionwhe...wheel/1763/867/
American Force Beast SS8 are also aluminum but rated for 6600 lbs each
http://americanforce...llection/item/7
#3 OFFLINE   fredandjoann
fredandjoann
  • 20 posts
Posted 28 March 2017 - 01:04 PM
Thanks Bedlam, I don't need the heavier capacity of the American Force or the heavier price.  The Vision wheels are a possibility but they don't have any offset which puts the center line out about 1.5 inches plus they require different lug nuts.  If Rickson doesn't come through I may have to go that way.
  • 1417 posts
Posted 28 March 2017 - 01:46 PM
Here are the Vision rims with 245/70R19.5 tires on my 2005 Ford:
#5 OFFLINE   vanceman
Posted 29 March 2017 - 03:44 AM
Are vision wheels made in china ? I have a set of Rickson wheels and tires on my 03 dodge srw and love them. Yes I too had to wait a little longer but its worth it and American made.I would stick with ricksons just my two cents.
  • 1925 posts
  • Local time: 12:39 AM
Posted 29 March 2017 - 07:00 AM
I looked at the 19.5 rims a little and saw one price at American force the price was like 3k each since I didnt look at others there cant say there all priced like those were. Vision were more reelistic in cost for a set of 9 were 2.3k. I just cant convence my self to order them. But to get double nickel tires may have to?
#7 OFFLINE   fredandjoann
fredandjoann
  • 20 posts
Posted 16 May 2017 - 11:18 AM
Solved my problem and now have a full set of 19.5" wheels, they came attached to a 2015 F450.  Will have to change my picture.
For now I'll be hauling my short bed Rainier on a long bed truck, at least for a little bit.  With the capabilities of the F450 I don't expect a problem but will be considering a long bed camper soon.
#8 OFFLINE   Bedlam
  • 1417 posts
Posted 16 May 2017 - 11:57 AM
I did the same with my short bed Arctic Fox on my Ram until I saved up for the Mammoth. Just make sure you put some blocks between the front of the camper and pickup bed so it does not creep forward. Depending on your front tie down location, you may find that the FastGun does not reach. You should be able to add some chain links to the camper tie down point to make up the distance the FastGun cannot extend.
#9 OFFLINE   fredandjoann
fredandjoann
  • 20 posts
Posted 16 May 2017 - 05:02 PM
Chain links were what I was thinking after I get it loaded and see just what is needed.  Thanks for the blocking heads-up, I'll build a 2x frame to fit the space.  I have the swing-out hinges for the front jacks on order.
#10 OFFLINE   kayakin
kayakin
    Director-Secretary-2015 Rally Committe Member
  • 828 posts
  • Camper Brand:2012 Adventurer 86FB
  • Truck Make & Model:2011 Chevy Silverado 4x4
  • Name (Public):Bonnie and Mike
Posted 19 May 2017 - 07:06 PM
There is always more than 1 solution to a problem.  That was thinking outside the wheel size box.
