If I was not towing with my F250, I would put down my rear jacks to limit suspension movement. When I had my trailer connected, I would drop the tongue jack to accomplish the same thing. With my 5500, it is stiff enough that I do not need drop the jacks for stability. When I did use the camper or tongue jacks, I would run them down until I saw just a little lift. This would slightly unload the suspension but did not rely on the jacks for the full weight.
2015 Ram 5500 HD 4wd Tradesman 60" CA, Crew cab with 173.4" wheelbase, 19,000 lb GVWR with 26,000 lb GCWR, Cummins I6 6.7 liter diesel with chassis cab tune 325 hp @ 2800 rpm and 750 ft-lb @ 1700 rpm, Aisin AS69RC 6-speed automatic, New Process NV271 manual transfer case, 14.5k lb Dana S14-111L limited slip and 7250 lb Magna Steyr 275mm with 4.44 ratios, Palfinger Badger low sill flat bed, Dual DeeZee 36x18x18 under bed boxes, Quad DeeZee 48x18x18 above bed boxes, Curt Double Lock 30K lb gooseneck, Dual 3/4" horse stall mats, SuperHitch Magnum 30K dual receiver with 42" SuperTruss, Upper StableLoads, Short range FastGun turnbuckles, 10 Deka 24HR3000 sealed batteries
