Camperjacks for 1997 Lance 8.6 Squire 3000 unit
jacks lance atwood
#1 OFFLINE   mondorama
mondorama
  • Local time: 09:20 PM
  • State/Province or Region:Limburg
  • Country:Netherlands
  • Truck Make & Model:dodge w250
Posted 19 November 2016 - 12:32 PM
Hi.
I would like to know what replacement jacks from atwood would fit my lance truck camper?
I tried to contact Lance HQ but until today no reply
I would like to knwo for mechanically ones and electric?
Is there somebody who knows?
Kind regards from the Netherlands, Europe
  • Local time: 03:20 PM
Posted 19 November 2016 - 07:36 PM
check with panther RV can get info from them im sure also they more than likely have a match there to yours the shipping will kill you.
#3 OFFLINE   TDWebster
  • 100 posts
  • Local time: 05:20 PM
Posted 20 November 2016 - 04:19 AM
+1 on Panther. Just bought a replacement set for mine from them, used the old power heads.
  • Local time: 02:20 PM
Posted 20 November 2016 - 10:13 AM
The Rieco Titan jacks share the same mounts as Atwoods if you want to expand your search beyond one manufacturer. If you can find power heads to fit your manual Atwood jacks, this would be the least expensive option. Although the entire jack assembly can be replaced with a Rieco Titan, I do not think you can use the power heads off one manufacturer for a jack assembly of another.
#5 OFFLINE   Boatfix
Boatfix
  • Local time: 10:20 PM
  • Camper Brand:BigFoot
  • Truck Make & Model:Dodge Cummins 3500 dually 4x4
  • Name (Public):BoatFix
Posted 14 October 2017 - 05:38 PM
I wore out two sets of electric Happijacks in 6 years. Then I discovered RIECO Titans. Do the comparo of the specs.
If I were Bigfoot, I would at least offer the option of RIECO over Happijacks. RIECO are for more robust.
I have the remote wireless which is a real plus.
Posted 14 October 2017 - 09:41 PM
As long as you keep the jacks oiled don't matter the brand they last a long time. I had replaced the jacks on our AF-990 that was almost 11 years old they lasted 9 and 10 years I replaced them as a pair I oiled them each year using transmission oil just a ounce or two is all you need but need to run the jacks out to there full travel each way easily done by removing the jack the makers say to drop a few drops of oil in the manual crank area where the small hole is I find it easyer to remove the motor and just pour the oil in and catch it in a pan on the ground.
Also tagged with one or more of these keywords: jacks, lance, atwood
