What not to do!
No replies to this topic
#1 OFFLINE   KnightEagle
  • 1950 posts
  • Local time: 02:05 PM
Posted 23 September 2016 - 06:22 PM
On the fridge's that are in our TC found one thing that not a wise thing to do unless you have 1300$$ to throw away. Read some where in the forum here or else where about stuffing hard insulation sheets around and block the vents on the side. Off and on over the last year and a half on our fridge, it would go into <no co> translating to that the unit not letting the gas cool down and it stays in vapor form and overheats and throws the code <no co>. First time it was in the shop back when they were replacing the roof, by the time they got to work on it the temp was plesant out and cool not the normal 100. They just reset it and it worked fine. We hadn't gotten out much this year But in May it worked perfect. But In Aug it started with the <no co> code again even replaced the board still got the code. So we loaded the fridge from our bedroom and took it so we would have a fridge to use sence the one in the fox was not working. As we were passing by PrencessCraft in Austin we droped the TC off. Well this time they found what was causing it. sence the fox has the ref in the slide the vent that would be on the roof is in the side wall. Well some one before to us install allum backed foum insolation board around the unit and blocked the vent. Belive they were trying to block the wind from blowing the flame out only thing i can think of?
