blog post on truck and setup
10 replies to this topic
  • 3741 posts
  • Local time: 06:29 AM
Posted 12 September 2016 - 05:51 AM
I pretty much have the camper all set up on the Dodge now. I still need to get the Lock and Load installed for the generator. I also need to move the under the truck flood lights installed like I had on the Chevy.
 The Dodge is doing great and the ride with the camper is fantastic.
https://thetclife.co...-ride-824-2016/
Thanks again Torklift!
#2 OFFLINE   Camper_Jeff_&_Kelli
Camper_Jeff_&_Kelli
  • 321 posts
  • Local time: 05:29 AM
  • Camper Brand:S&S 9.5SC 2000 Model Year
  • Truck Make & Model:FORD F250 4x4
  • Name (Public):Jeff
Posted 12 September 2016 - 06:08 AM
Look at that back seat, I bet you could get 4 weenie dogs back there! Be nice to install a sliding window in the step of the TC for access to the storage bin in the bed if there are going to be items needed in there. It would also give you rear view mirror usability out the back of the TC.
Nice setup. Hope you get many years out of it.
<img src='https://pqeo5g.bn1.l...humb.jpg?psid=1' alt='Posted Image' class='bbc_img' /><br />Tatoosh Island .5 miles offshore in the distance from Cape Flattery, the Northwestern tip of the lower 48 United States, the Olympic Peninsula, and Washington State, also the entrance to the Strait of Juan de Fuca and Puget Sound. Home of the Makah People.<br /><br />Visit Our Blog:<br /><a class='bbc_url' href='http://camperjeffandkelli.wordpress.com/'>http://camperjeffandkelli.wordpress.com/</a>
#3 OFFLINE   the tc life
  • 3741 posts
Posted 12 September 2016 - 06:49 AM
Not just 4...5 dachshunds...oh yeah....and a kid. See you next month Jeff.
  • 1432 posts
Posted 12 September 2016 - 07:42 AM
1. You're going to need to use wipers your more often without that overhang above your windshield (voice of experience here).
2. Will you put the Lock and Load for the generator up front this time?
3. Will your grill fit the rear without blocking access?
4. What about making your storage box cab high with side doors instead of bed rail height?
#5 OFFLINE   KnightEagle
  • 1938 posts
  • Local time: 07:29 AM
Posted 12 September 2016 - 08:57 AM
Like the ride the box seems to be a great idea will it hold up to forward pressures of the TC if it try's to slide forward didnt see bracing to apsorb the presure to the front of the bed wall.
#6 OFFLINE   Torklift
Torklift
  • Manufacturers (Aux Equip)
  • 397 posts
  • Gender:Not Telling
  • Interests:RVs, truck campers, hitches, aftermarket steps, long walks through the manufacturing plant
Posted 12 September 2016 - 09:14 AM
Great write up Rich! The rig and camper look like a fun setup. We're happy to hear that everything installed well and you're good to go on another adventure!
Visit Torklift's blog to read up on all the latest posts, reviews and more: http://www.torklift.com/blog
#7 OFFLINE   the tc life
  • 3741 posts
Posted 12 September 2016 - 10:28 AM
Seems to do very well. It's pretty darn strong and not the lightest thing. Lol
#8 OFFLINE   the tc life
  • 3741 posts
Posted 12 September 2016 - 10:32 AM
Pete...get out of my head...lol....those are thoughts I'm working on still. Thinking about building a bigger box with side doors.
Getting front hitch today for lock and load...
The grill we are putting on a table but hook up the propane hose to camper still.
Wiper blades....I'm on the dry side of the state. Lol.
#9 OFFLINE   KnightEagle
  • 1938 posts
Posted 12 September 2016 - 01:21 PM
We have 1001 ideas for you
#10 OFFLINE   Bedlam
  • 1432 posts
Posted 12 September 2016 - 01:32 PM
It's easier to spend someone else's money than our own.
#11 OFFLINE   the tc life
  • 3741 posts
Posted 12 September 2016 - 02:23 PM
Lol.
Got the front hitch receiver.... Seeing about installing it tonight.
I'm out of money by the way.
