beer or wine taps built in the camper?
22 replies to this topic
#21 OFFLINE   the tc life
  • 3745 posts
  • Local time: 06:59 AM
Posted 29 May 2016 - 03:35 PM
running it through a jockey box will keep the beer cold at the tap.
so dang busy with both jobsa and then spending some free time doing whatever, i have not started the project. i may just do a jockey box from the brewery for the montana rally.
#22 OFFLINE   Bedlam
Posted 12 February 2017 - 10:54 AM
Until you figure out your beer tap, here are some stops you can schedule while traveling:
https://roadbrewing.com/
#23 OFFLINE   the tc life
  • 3745 posts
Posted 13 February 2017 - 06:37 AM
Thanks for the link.
The project is on hold with the new truck set up I have.
