New hope for diesel fuels
12 replies to this topic
#1 OFFLINE   RichConley
  • 2131 posts
  • Local time: 11:09 AM
Posted 19 December 2015 - 06:54 AM
The production of diesel fuels involves the use of catalysts.  A new discovery shows how to make cleaner burning diesel fuel.
Researchers from KU Leuven and Utrecht University have discovered a new approach to the production of fuels. Their new method can be used to produce much cleaner diesel. It can quickly be scaled up for industrial use. In 5 to 10 years, we may see the first cars driven by this new clean diesel.
Story:   http://www.kuleuven...._cleaner_diesel
#2 OFFLINE   PigPen
  • 12475 posts
Posted 20 December 2015 - 10:27 PM
Good news. No matter how much we move to renewable, clean energy, diesel fuel is going to be needed to move freight for along time yet.
#3 OFFLINE   KnightEagle
  • Local time: 01:09 PM
Posted 21 December 2015 - 11:22 AM
At one time Diesel was the waste product of refining gas and the cheapest. Now it cost more than super unleaded. And now some have to add extra oil to there fuel or some kind of additive?
  • 1381 posts
Posted 21 December 2015 - 11:32 AM
Engines that were designed prior to the ultra low sulfur diesel change need additional lubricants added to reduce injector wear. Some people also claim that the Bosch CP4 fuel pump lasts longer with the same additive on newer diesels. This is similar to what was required on old engines designed for leaded gasoline verses unleaded.
2012 Interstate Car Carrier ICC10220TA3, 20'x8.5', 8" I-beam frame, dual 5200 lb 4" drop torsion axles, Diamond plate, Towmax 225/75R15 LRE tires on galvanized rims, Harbor Freight 10k lb equalizing hitch, Camping World vent cover, LED lighting, 3' RV door, front and rear door interior light switches, interior plywood walls and floor, 70' of Harbor Freight E-track rail with recessed corner 5k lb D-rings, Dual 42 gal fresh water tanks with Harbor Freight transfer pump, portable dual  Harbor Freight 45w solar arrays, 100 lbs LPG in four bottles, PowerArmor Max Solar 5-battery box, Deka 24HR3000 sealed batteries
2015 Ram 5500 HD 4wd Tradesman 60" CA, Crew cab with 173.4" wheelbase, 19,000 lb GVWR with 26,000 lb GCWR, Cummins I6 6.7 liter diesel with chassis cab tune 325 hp @ 2800 rpm and 750 ft-lb @ 1700 rpm, Aisin AS69RC 6-speed automatic, New Process NV271 manual transfer case, 14.5k lb Dana S14-111L limited slip and 7250 lb Magna Steyr 275mm with 4.44 ratios, Palfinger Badger low sill flat bed, Dual DeeZee 36x18x18 under bed boxes, Quad DeeZee 48x18x18 above bed boxes, Curt Double Lock 30K lb gooseneck, Dual 3/4" horse stall mats, SuperHitch Magnum 30K dual receiver with 42" SuperTruss, Upper StableLoads, Short range FastGun turnbuckles with locks
2018 Host Mammoth 11.5, Polarized dual pane windows, Powered and lit awning, Swing out Rieco-Titan jacks,  Fantastic Fan in cab over, Aero-Flo vent covers, 3x160w Zamp Solar with 30A controller, External 24" TV with DVD, Cargo slide tray, dual 6-volt batteries, 2.5KW LPG Onan, External LPG connection, 2-way water heater, Therford 3-burner cook top, Convection/Microwave, 8 cu ft 2-way Norcold Fridge, Loveseat with foot rest, U-shaped dinette, 1000W PSW Zamp inverter, King Jack amplified OTA antenna, 40" Samsung UN40J5200 smart TV in living room, Electric fireplace with heater, Accordion bedroom door, Full wall passenger-side cab over wardrobe, 32" Samsung UN32J5205 smart TV in Bedroom
#5 OFFLINE   PigPen
  • 12475 posts
Posted 21 December 2015 - 09:24 PM
All I know is mine runs much better on Mexican diesel (no ULSD)
#6 OFFLINE   Bedlam
  • 1381 posts
Posted 21 December 2015 - 09:52 PM
The older diesels also ran well on B10 due to the extra lubricity without needing additives. I mixed B15 with #2 before but never ran B15 or B20 straight in my old engine. My new engine is certified for B20 use. Unlike gasohol, biodiesel does not suffer a mileage penalty but it does have a shorter shelf life than #2.
#7 OFFLINE   RedneckExpress
  • 3208 posts
Posted 22 December 2015 - 05:15 PM
And it does a wonderful job of cleaning your gas tank and depositing everything it removed in your filters ;)
#8 OFFLINE   Bedlam
  • 1381 posts
Posted 22 December 2015 - 07:00 PM
You don't get that build up if you use bio mix often. Typically this an issue with someone who had an old diesel fed on dino oil and suddenly had a change of diet using straight bio oil. It's well documented that you have to change filters often until your fuel system is clean and should be no surprise for someone going to that extreme. Running B10 or B20 typically does not have those issues unless you already started with a problem.
#9 OFFLINE   DakotaCamper
Posted 25 December 2015 - 05:53 PM
Can somebody hook up the folks at VW with this? LOL. We own one of the TDIs currently under fire because of the software cheater issue. Our 2014 Passat has the AdBlue system but I guess it still is a problem. I am NOT giving up my car without a fight because we do get great fuel mileage. I see these trucks that "roll coal" and know the emissions have to be much greater than my Passat. Maybe the change in diesel fuel will help offset this.
#10 OFFLINE   KnightEagle
Posted 26 December 2015 - 06:32 AM
Never thought a VW blowing coal Hmmmm lol
#11 OFFLINE   RichConley
  • 2131 posts
Posted 26 December 2015 - 07:21 AM
Nothing extra added. . .just changing the formula.  Consumer grade diesel fuel costs more because the federal government added a 50-cent tax on every gallon of diesel back when gas was cheaper than diesel and people began to think about buying diesel powered vehicles.
#12 OFFLINE   Squish
Squish
  • 7 posts
  • Local time: 07:09 PM
  • State/Province or Region:Ca
Posted 26 June 2016 - 04:49 PM
Hmm that's funny I thought the federal fuel tax on diesel was pegged at $.24 a gallon.
https://www.eia.gov/....cfm?id=10&t=10
From where do you get your figure?
Edited by Squish, 26 June 2016 - 04:51 PM.
#13 OFFLINE   butch50
butch50
    Vice President / Director
  • Directors
  • 182 posts
  • State/Province or Region:AR
  • Camper Brand:2017 Nexus Ghost 36DS (Being Built)
  • Truck Make & Model:2014 Jeep Grand Cherokee (AKA Toad)
  • Name (Public):Butch
Posted 09 July 2016 - 07:21 AM
The federal tax on diesel is about $0.244 per gallon and then the states add their tax on it which in a lot of cases brings the total tax to around $.50 a gallon.
