camper license tabs (washington)
23 replies to this topic
#21 OFFLINE   RichConley
  • 2160 posts
  • Local time: 02:01 PM
Posted 29 May 2015 - 01:19 PM
I'm still studying Colorado passes to figure out what I may need for access...
Good point.  We just got a Jeep Rubicon which we'll be toading to the rally.
I'm still waiting on the supplemental braking system part, anticipating it's install, and had not even thought of the potential permits for it in Colorado.
#22 OFFLINE   Bedlam
Posted 29 May 2015 - 01:33 PM
If you stray off the roads, you need a non-resident OHV permit regardless of how your vehicle is licensed. There is no reciprocity with WA like some other states honor.
http://cpw.state.co....rationsOHV.aspx
Here is some park pass information:
http://cpw.state.co....ksPassInfo.aspx
#23 OFFLINE   RichConley
  • 2160 posts
Posted 29 May 2015 - 04:17 PM
Probably should post that in the rally topic.
#24 OFFLINE   poriggity
poriggity
  • Local time: 03:01 PM
  • Truck Make & Model:Dodge Ram 2500
  • Name (Public):Scott
Posted 26 June 2015 - 02:43 PM
That's probably the ONLY good thing about CA, there is no seperate registration for truck campers, we just move the plate from our truck to the TC, and we're good.  That's about all I like about CA.  The rest of the state is garbage.
2004.5 Dodge Ram 2500 Quad Cab Long Bed 4x4. 5.9 Cummins NV5600 6 speed Manual
1988 Lance LC980 Truck Camper - dubbed "problem child"
