Pacific Northwest Spring Rally. April 12, 13, 14, 2013.
60 replies to this topic
#41 OFFLINE   Camper_Jeff_&_Kelli
Camper_Jeff_&_Kelli
  • 321 posts
  • Local time: 06:24 PM
  • Camper Brand:S&S 9.5SC 2000 Model Year
  • Truck Make & Model:FORD F250 4x4
  • Name (Public):Jeff
Posted 11 April 2013 - 09:21 AM
We will lift our burgers in salute as recognition to your good works Rich!
<img src='https://pqeo5g.bn1.l...humb.jpg?psid=1' alt='Posted Image' class='bbc_img' /><br />Tatoosh Island .5 miles offshore in the distance from Cape Flattery, the Northwestern tip of the lower 48 United States, the Olympic Peninsula, and Washington State, also the entrance to the Strait of Juan de Fuca and Puget Sound. Home of the Makah People.<br /><br />Visit Our Blog:<br /><a class='bbc_url' href='http://camperjeffandkelli.wordpress.com/'>http://camperjeffandkelli.wordpress.com/</a>
#42 OFFLINE   Camptoboat
Camptoboat
  • 1124 posts
  • Local time: 07:24 PM
  • Interests:Boating in the sun....
  • Camper Brand:2006 Citation Supreme 1050 w/slide
  • Truck Make & Model:1999 Ford F350 crewcab DRW
Posted 11 April 2013 - 09:43 AM
Well we to are in the almost ready status. Camper is on the truck and loaded with water. Will struggle to make the bed, then load the last of the stuff.
Blasting off from Lake Stevens park-n-ride around 5:30-6:00ish, see ya in an hour or so.
Bedlam, need not worry about Chili for us.
Gary & Hazel
1999 Ford F-350 Crew Cab DRW, synthetic oil every where, Fleetguard Venturi Combo Oil Filter, Auto, BHAF, Edge w/Advantage controller and gauges, CCV MOD, Timbrens, Exhaust brake/TC lock by Sp Diesel , Brite Box (head light control), Coolant filter, Boost fooler (25 PSI max), High pressure cross-over tube, Hayden Ultra-Cool® Transmission Oil Cooler, Digital Trans temp, Magnefine Trans Filter, Ford AIC. Northwest Fords forum, Powerstroke Org.
2006 Citation 1050 rear kitchen, refer & dinette slide (Roy Robinson Marysville, WA.), Laptop and MS Street and Trips w/GPS navigation.
Torklift Fastgunns, Wobbl-Stoppers on front jacks, Dish network, 20� LCD w/DVD TV, Honda EU2000i. Prosine 2000 inverter/charger.
1992 Maxum 19' bowrider
#43 OFFLINE   Camper_Jeff_&_Kelli
Camper_Jeff_&_Kelli
  • 321 posts
Posted 11 April 2013 - 11:00 AM
We are heading up Friday.
#44 OFFLINE   farmer
Posted 11 April 2013 - 06:18 PM
We should be there by noon Sat, after check in may meet you guys up at Mt. Erie
#45 OFFLINE   smokeypointer
smokeypointer
  • 164 posts
  • Interests:Golf, Camping, Starting Projects Around The House That I Never Finish
  • Camper Brand:2009 Pastime 840LT
  • Truck Make & Model:2006 Silverado 1500HD Crew
  • Name (Public):Robin & Clare
Posted 11 April 2013 - 06:26 PM
"An hour or so"? From the Lake Stevens park-n-ride? Just how fast are you planning to drive? It'll take me an hour and you've got 20-30 minutes to get past my place. Or have you found a shortcut across the water? See ya tomorrow.
<p>Robin & Clare<br><img src="http://www.truckcamp...59_145_5652.jpg" alt="gallery_4159_145_5652.jpg"></p>
<div> VisitedStatesMap201404
</div>
<p> </p>
</div>
<p><span style="font-size:14px;"><span style="font-family:'Arial Black';">A few more places left to camp!</span></span></p>
#46 OFFLINE   Bedlam
Posted 12 April 2013 - 05:58 PM
SmokeyPointer and Badlam are settled in at the campground. Come on over for chilli when you get in tonight and save having to cook something up.
JTLingo123 has arrived with family. We'll just have to wait till morning to see who else pulled in.
Edited by Bedlam, 12 April 2013 - 08:35 PM.
#47 OFFLINE   Camper_Jeff_&_Kelli
Camper_Jeff_&_Kelli
  • 321 posts
Posted 12 April 2013 - 10:18 PM
We are here finally. Stopped at Costco to get all the food items and a very nice 10x10 pop up canopy for over the table. Snoqualmie Falls Pancakes, sausages, eggs, coffee, in the morning. Of all Things to forget, I forgot my Coleman propane stove so I will have to cook on the TC stove. No biggie, there'll be a fire. See you in the morning starting at 8:00. Site 166.
J&K
#48 OFFLINE   Camper_Jeff_&_Kelli
Camper_Jeff_&_Kelli
  • 321 posts
Posted 13 April 2013 - 08:21 AM
Breakfast under the tent. 9:15 now.
#49 OFFLINE   Camper_Jeff_&_Kelli
Camper_Jeff_&_Kelli
  • 321 posts
Posted 14 April 2013 - 06:49 AM
Posted: 04/14/13 07:41am
Link | Quote | Edit | Print | Notify Moderator
Grilled about 16 burgers and 20 chicken thighs. Food was grilled and smoked seeming to disappear as fast as it would come off the grill. No complaints reported from any of the test subjects. Best of all, the hungry heathens were kind enough to be satisfied and did not hang the chef.
There was plenty of food. Bedlam brought a great homemade 5 bean Chile. Mrs Bedlam is running a full marathon this am and we're cheering her on. It's been a nice weekend catching up with old friends. J
#50 OFFLINE   the tc life
  • 3741 posts
Posted 14 April 2013 - 07:48 AM
:thumbs_up:
great to hear you all had a good time.
#51 OFFLINE   Bedlam
Posted 14 April 2013 - 01:07 PM
Mrs. Bedlam not only survived the 26.2 mile run, she came in second in her age group. After a hot shower and coffee we are ready to wind our way home. Thanks to Jeff and Kelli for organizing this gathering.
#52 OFFLINE   the tc life
  • 3741 posts
Posted 14 April 2013 - 03:29 PM
congratulations to her. great job!
#53 OFFLINE   kayakin
kayakin
    Director-Secretary-2015 Rally Committe Member
  • 829 posts
  • Local time: 08:24 PM
  • Camper Brand:2012 Adventurer 86FB
  • Truck Make & Model:2011 Chevy Silverado 4x4
  • Name (Public):Bonnie and Mike
Posted 14 April 2013 - 05:10 PM
26.2 miles?  I am VERY impressed!
#54 OFFLINE   Camper_Jeff_&_Kelli
Camper_Jeff_&_Kelli
  • 321 posts
Posted 14 April 2013 - 08:43 PM
Mrs Bedlam crossing the marathon finish line.
#55 OFFLINE   farmer
Posted 14 April 2013 - 09:52 PM
Thankyou
Jeff and Kelli
Bowman beach and the C C C display was a history lesson.
We had hail on our beach walk, still better than a day at work.
Now have to see the Ballard locks in your neck of woods.
Rick and Susanne
#56 OFFLINE   Camptoboat
Camptoboat
  • 1124 posts
Posted 15 April 2013 - 06:18 AM
Yes, Thankyou
Jeff and Kelli we had a great time, the food was great.
It was nice the sky's parted Saturday evening made for a good time around the fire.
Congrats to Mrs. Bedlam for the marathon finish too.
#57 OFFLINE   Bedlam
Posted 15 April 2013 - 09:20 AM
We were not geeks just talking about our truck campers around the campfire. We also were geeks talking more geeky things:
#58 OFFLINE   Camper_Jeff_&_Kelli
Camper_Jeff_&_Kelli
  • 321 posts
Posted 15 April 2013 - 09:24 AM
EXACTLY !!!
#59 OFFLINE   Camper_Jeff_&_Kelli
Camper_Jeff_&_Kelli
  • 321 posts
Posted 16 April 2013 - 01:01 PM
Here's a couple photos. I'll do up a report soon.
PNW%20Spring%20Rally%2004_12_2013%20056.
PNW%20Spring%20Rally%2004_12_2013%20078.
PNW%20Spring%20Rally%2004_12_2013%20100.
PNW%20Spring%20Rally%2004_12_2013%20124.
PNW%20Spring%20Rally%2004_12_2013%20141.
PNW%20Spring%20Rally%2004_12_2013%20146.
PNW%20Spring%20Rally%2004_12_2013%20153.
J
#60 OFFLINE   butch50
butch50
    Vice President / Director
  • Directors
  • 182 posts
  • Local time: 09:24 PM
  • State/Province or Region:AR
  • Camper Brand:2018 Grand Design Reflection 303RLS
  • Truck Make & Model:2017 Ram Mega 3500 Dually
  • Name (Public):Butch
Posted 20 April 2013 - 12:31 PM
Wow I see in the second picture that you had the breakfast of CHAMPIONS. Pancakes with maple syrup and a BudLight. What more can a guy ask for.   :happy0064:
Looks a good time was had.
