This forum will close down forever in just under 3 weeks
74 replies to this topic
#61 OFFLINE   Bedlam
  • Local time: 02:25 AM
Posted 21 December 2012 - 05:49 PM
Bummer, I was looking forward to warmer temps, its snowing here today. I am headed south on boxing day, Hope I can make it through the siskiyou pass.
If the weather is harsh over the pass into CA, consider veering off to Florence,OR or Reedsport and follow the coast until you are in Eureka, CA.
#62 OFFLINE   mtnkwby
  • 398 posts
  • Local time: 01:25 AM
  • Camper Brand:Looking
  • Truck Make & Model:Looking
Posted 21 December 2012 - 09:04 PM
Dang............still have to pay the bills!
Currently Tent Campers
1963 IH Scout 80 DD
1964 IH Scout 80 (project)
1978 CB750K bagger
#63 OFFLINE   RedneckExpress
  • 3209 posts
Posted 23 December 2012 - 06:00 AM
I win, someone owes me a set of scissors steps or some spring loaded happijac turnbuckles :P.
#64 OFFLINE   DEC
DEC
  • 218 posts
  • State/Province or Region:Utah
  • Interests:4-wheeling, camping, hiking, fishing, and astronomy
  • Camper Brand:Outfitter Apex 8
  • Truck Make & Model:2007 Dodge Ram 3500 CTD
  • Name (Public):Don Curley
Posted 23 December 2012 - 06:23 AM
If you end up with some spring loaded happijac turnbuckles, you lost! :tongue0013:
- 2007 Dodge Ram 3500 Heavy Duty QC SB SRW 4x4 with 6.7L Cummins turbo diesel, 68RFE 6-speed automatic transmission, 9.25 front axle/11.50 rear axle with AAM TracRite-GT limited slip differential, exhaust brake, 35" Toyo Open Country M/T tires mounted on Power Wagon 17x8 forged aluminum wheels, Tuff Country 2.5" front leveling kit, Firestone Ride-Rite air bags (with in-cab controls, compressor & tank), Rancho RS9000XL shocks, full array of skid plates, Amp Research power retractable running boards, Buckstop Baja front bumper with Warn 16.5ti 16,500 winch, 6" PIAA 580 driving lights, and 4" PIAA 510 fog lights, Road Armor rear bumper with PIAA back-up lights, Line-X bedliner with Line-X Xtra Kevlar overcoat, and Undercover tonneau cover.
- 2007 Outfitter Apex 8 customized & modified with 220W solar, Blue Sky Solar Boost 2000E MPPT controller, twin 6 volt T-145 Trojan batteries, Xantrex Prosine 2000W inverter/converter/charger, Honda EU2000i, Tundra fridge, Polar Cub A/C with remote digital thermostat/controls, Suburban 20K BTU furnace, Atwood XT water heater, ShurFlo Extreme 4 variable speed water pump, Suburban cook top with oven, microwave, twin Fantastic fans, Happijac tie-down system with Fast Guns, electric Happijac jacks, side/rear awnings, stereo system with outside speakers.
- 2000 Jeep Wrangler TJ 4x4 highly modified with 5.9L Magnum V8 ... locked & loaded.
#65 OFFLINE   smokeypointer
smokeypointer
  • 164 posts
  • Interests:Golf, Camping, Starting Projects Around The House That I Never Finish
  • Camper Brand:2009 Pastime 840LT
  • Truck Make & Model:2006 Silverado 1500HD Crew
  • Name (Public):Robin & Clare
Posted 23 December 2012 - 04:02 PM
Don't forget to take Tomas this time    :sign0007:
<p>Robin & Clare<br><img src="http://www.truckcamp...59_145_5652.jpg" alt="gallery_4159_145_5652.jpg"></p>
<div> VisitedStatesMap201404
</div>
<p> </p>
</div>
<p><span style="font-size:14px;"><span style="font-family:'Arial Black';">A few more places left to camp!</span></span></p>
#66 OFFLINE   RedneckExpress
  • 3209 posts
Posted 23 December 2012 - 07:44 PM
Well, kinda need happijacs, given that I have happijac tie downs :P.
#67 OFFLINE   DEC
DEC
  • 218 posts
Posted 23 December 2012 - 08:42 PM
I also have Happijac tie-downs, but I got rid of my Happijac turnbuckles because they suck (especially off-road).  I then went with Torklift .45 Fast Guns and have never looked back. :tongue0013:
#68 OFFLINE   jamminalong
jamminalong
  • 347 posts
  • Gender:Not Telling
  • Interests:hiking & fishing
  • Camper Brand:1998 Lance-Squire Lite 165
  • Truck Make & Model:Chevy 2500HD 4x4
  • Name (Public):~M
Posted 26 December 2012 - 05:21 PM
Here's what I have... are they spring loaded???
jamminalong
98 Lance Squire Lite 165
Chevy 2500HD SB 4x4
#69 OFFLINE   RedneckExpress
  • 3209 posts
Posted 26 December 2012 - 07:20 PM
Yup, those should be the Happijac spring loaded turnbuckles :).
#70 OFFLINE   jamminalong
jamminalong
  • 347 posts
  • Name (Public):~M
Posted 26 December 2012 - 07:25 PM
Then they are yours! We'll have to figure something out unless you can hold off for a spring rally or something.
I have fastguns for my TC.
jamminalong
Chevy 2500HD SB 4x4
#71 OFFLINE   DEC
DEC
  • 218 posts
Posted 26 December 2012 - 09:36 PM
This should be common knowledge, but keep in mind that the original Happijac stainless steel turnbuckles come in two versions ... spring-loaded and the more simple rubber damping turnbuckles (and as far as I can tell, they look essentially similar from the outside).  Typically, you use a pair of the spring-loaded versions in the front with a pair of the rubber damping turnbuckles in the rear.  In challenging off-road conditions I have found that the rubber damping type literally eat their rubber bushings in fairly short order.  The problem with the spring loaded versions in the same conditions is that they start squeaking like crazy and won't stop even with on-highway operation.  Even with our cab windows closed, the extreme squeaking was totally annoying.  Switching to four spring-loaded Torklift Fast Guns cured all of these problems.
Edited by DEC, 26 December 2012 - 09:37 PM.
#72 OFFLINE   jamminalong
jamminalong
  • 347 posts
  • Name (Public):~M
Posted 26 December 2012 - 10:22 PM
I'm using my fastguns, which I prefer.
I got the happijac's when I bought the TC. Figured I might as well take them in case someone was looking for a set or needed to borrow for transporting their TC after a purchase. Since Matt needs/wants them, he can have them. I have no clue about them.
Matt do you plan on doing the spring campout? What about the Montana Rally?
jamminalong
Chevy 2500HD SB 4x4
#73 OFFLINE   RedneckExpress
  • 3209 posts
Posted 27 December 2012 - 01:59 AM
Unfortunately, I don't know when I'll be on the road again, Montana and the spring rally will both be hitting in the middle of contract, so I won't be able to make either.
The closest would have been the January bit, but I don't ski, and the truck still needs repairs, January is new brake booster and master cylinder month as the master cylinder started leaking and weak power on my way home from the Midwest.
The tube length is different between the non dampened and dampened turnbuckles, the shorter two, as you can see in the picture have the longer barrels, which I believe are the two spring loads, the rear rubber loads have the shorter barrel and longer bar for reaching down to your bumper, which is what comes in a standard happijac turnbuckle set, two short for the front with springs and two long for the rear without
#74 OFFLINE   jamminalong
jamminalong
  • 347 posts
  • Name (Public):~M
Posted 27 December 2012 - 10:30 AM
Find out who the closest person is to you and hopefully they'll be at a rally that I can pass them off to. I just don't think shipping costs would be worth it because of weight.
I know we have plans to come over to that side of the state sometime this summer if all goes well. I'm sure we'll figure something out. Regardless they're yours until I hear otherwise.
jamminalong
Chevy 2500HD SB 4x4
#75 OFFLINE   RedneckExpress
  • 3209 posts
Posted 28 December 2012 - 12:48 AM
Sooty would be the only person really left from Oregon that still attends Rallies that is near my area that I know, but I haven't a clue if he's attending any of the up coming rallies.
